I was wondering if using color correction filters would be pointless if you bounced it against a ceiling or wall? Shot through an umbrella?
ilzephyrli Member 35 posts Joined Sep 2009 More info | Dec 15, 2010 19:26 | #1 I was wondering if using color correction filters would be pointless if you bounced it against a ceiling or wall? Shot through an umbrella? 7D 2x | Tamron 17-50 f2.8 VC | Sigma 30mm f1.4 | 70-200 f/4L |
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Dec 15, 2010 19:34 | #2 ilzephyrli wrote in post #11459628 I was wondering if using color correction filters would be pointless if you bounced it against a ceiling or wall? Shot through an umbrella? The answer to your question depends on a lot of variables. What's the color of the ceiling and/or wall? How much flash power do you have relative to the ambient lighting, especially with a light-absorbing gel over the flash? Etc. Skip Douglas
Dec 15, 2010 23:03 | #3 Thanks for the reply. I wanted to know if bouncing on a colored ceiling like beige for example would change the light of a filtered flash. I'm trying to even the ambient light with the flash. Thanks! 7D 2x | Tamron 17-50 f2.8 VC | Sigma 30mm f1.4 | 70-200 f/4L |
charlesml3 Member 245 posts Joined Oct 2008 More info | Dec 16, 2010 07:42 | #4 Of course it will. Anything that the flash hits or shoots through that has a color cast will change the temp of the flash.
Dec 16, 2010 22:47 | #5 So the only way to make use of gels to use direct flash? 7D 2x | Tamron 17-50 f2.8 VC | Sigma 30mm f1.4 | 70-200 f/4L |
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Dec 17, 2010 00:28 | #6 ilzephyrli wrote in post #11466829 So the only way to make use of gels to use direct flash? Not quite. You can use a white umbrella, a white bounce card, or white walls and ceiling as modifiers without changing the color of the light. Skip Douglas
Dec 17, 2010 10:32 | #7 Thanks! That's what I needed to know. 7D 2x | Tamron 17-50 f2.8 VC | Sigma 30mm f1.4 | 70-200 f/4L |
| Latest registered member is ealarcon 469 guests, 139 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
