Did you all start using the camera in FULL MANUAL mode or start with aids like Av, Tv, etc?
What are the pros and cons to both? Which was more helpful to you?
iamchanel Member 82 posts Joined Dec 2010 Location: Nation's Capital More info | Dec 16, 2010 15:08 | #1 Did you all start using the camera in FULL MANUAL mode or start with aids like Av, Tv, etc?
themadman Cream of the Crop 18,871 posts Likes: 14 Joined Nov 2009 Location: Northern California More info | Dec 16, 2010 15:12 | #2 I still use Av and Tv... Will | WilliamLiuPhotography.com
Snydremark my very own Lightrules moment More info | Dec 16, 2010 15:13 | #3 I started using the semi-auto modes because it gave me fewer things to think about at any one time; however, the downside to that was that it was harder for me to follow what was going on with the rest of my exposure because the camera was doing it for me. - Eric S.: My Birds/Wildlife
numbersix fully entitled to be jealous 8,964 posts Likes: 109 Joined May 2007 Location: SF Bay Area More info | Dec 16, 2010 15:18 | #4 When I first started I used full manual because there wasn't anything else. That was 40+ years ago. "Be seeing you."
tonylong ...winded More info | Dec 16, 2010 15:49 | #5 You should get a broad variety of answers to this because people come into this from all kinds of levels of experience and understanding. So, one person will jump into shooting Manual, on into Av or Tv, one into P and one into Auto/Green Box or using the Auto Scene Modes. Tony
Beau1k Senior Member 295 posts Joined Oct 2010 More info | Dec 16, 2010 16:29 | #6 There should be a hand held button option! Like Av+H 7D - Transcend 32GB 600x - 70/200 IS II & 17-55 - Dolica Proline Carbon Fiber
Sorarse Goldmember 2,193 posts Likes: 25 Joined Jan 2008 Location: Kent, UK More info | Dec 16, 2010 16:45 | #7 Beau1k wrote in post #11464915 There should be a hand held button option! Like Av+H Problem with AV mode is that the shutter speed can become so long that if you are hand holding your pic may come out supper blurry. With TV at least you can hedge your bet and choose a speed that's appropriate to hand holding. Same can be done in M but again with M it's not as quick and takes more setup time.I disagree. If shooting in Av mode, it should be second nature to check what shutter speed the camera is giving you, and if it's likely to give you problems with camera shake, either dial in a wider aperture setting or up the ISO. At the beginning of time there was absolutely nothing. And then it exploded! Terry Pratchett
Johnnyk_1 Senior Member 345 posts Joined Dec 2010 Location: Nashville, TN More info | Dec 16, 2010 16:51 | #8 just started like 2 wks ago and been shooting in M, pics dont come out all the great but i do know how to correct to get correct exposure. Still learning a bunch!
L.J.G. "Not brigth enough" More info | Dec 16, 2010 16:56 | #9 Johnnyk_1 wrote in post #11465044 just started like 2 wks ago and been shooting in M, pics dont come out all the great but i do know how to correct to get correct exposure. Still learning a bunch! Have you tried using auto to get the right shot, then reading the exif data to learn from it? Lloyd
MP4/8 Senior Member 689 posts Joined Jul 2010 Location: Mississauga ON, Canada More info | Dec 16, 2010 16:58 | #10 Permanent banBeau1k wrote in post #11464915 There should be a hand held button option! Like Av+H Problem with AV mode is that the shutter speed can become so long that if you are hand holding your pic may come out supper blurry. With TV at least you can hedge your bet and choose a speed that's appropriate to hand holding. Same can be done in M but again with M it's not as quick and takes more setup time.What kind of light are you shooting in, and what is your ISO? Canon T2i ** EF-S 17-55 f/2.8 ** EF 70-300 f/4-5.6 IS ** EF 50mm f/1.8 II ** EF-S 60mm f/2.8 Macro ** Lensbaby ** Canon S5 IS P/S camera
numbersix fully entitled to be jealous 8,964 posts Likes: 109 Joined May 2007 Location: SF Bay Area More info | Dec 16, 2010 16:59 | #11 Sorarse wrote in post #11465010 I disagree. If shooting in Av mode, it should be second nature to check what shutter speed the camera is giving you, and if it's likely to give you problems with camera shake, either dial in a wider aperture setting or up the ISO. Sure. "Be seeing you."
Thanks for all these really great replies. Wow, everyone does do it differently.
35mmNewbie Goldmember 2,127 posts Joined Mar 2010 Location: Coconut Creek, Florida More info | Dec 16, 2010 17:16 | #13 Full auto look at what the camera read, then switch over to manual and play with the settings. Now I still shoot full manual and love it. Bryan
MP4/8 Senior Member 689 posts Joined Jul 2010 Location: Mississauga ON, Canada More info | Dec 16, 2010 17:27 | #14 Permanent ban35mmNewbie wrote in post #11465166 Full auto look at what the camera read, then switch over to manual and play with the settings. Now I still shoot full manual and love it. You can do the same with starting in Av mode, after you've selected the aperture for the DOF you want, snap a pics, look at the shutter speed that the camera selected to get the proper exposure, and then dial that in, along with your aperture, in M mode, and start firing away. Canon T2i ** EF-S 17-55 f/2.8 ** EF 70-300 f/4-5.6 IS ** EF 50mm f/1.8 II ** EF-S 60mm f/2.8 Macro ** Lensbaby ** Canon S5 IS P/S camera
JeffreyG "my bits and pieces are all hard" More info | Dec 16, 2010 17:28 | #15 I first got 'serious' about photography four or five years ago, and that first year I shot pretty much entirely in Av mode. Realistically it works OK, but you do end up dealing with the shortcomings of reflective meters which limits your ability to really push the limits in tough light. My personal stuff:http://www.flickr.com/photos/jngirbach/sets/
| Latest registered member is ealarcon 1180 guests, 175 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
