Will the 24-105 f4 do as good a job with indoor flash as the 24-70 f2.8
L.Morey Goldmember 1,571 posts Joined Oct 2005 Location: Modesto Ca More info | Dec 16, 2010 15:21 | #1 Will the 24-105 f4 do as good a job with indoor flash as the 24-70 f2.8 7d gripped,40d gripped,G9,17-40f4L, 24-70f2.8 L, 70-200f2.8 mkll L, 100-400 f4.5-5.6 L, 50f1.4 , 85f1.8 , Sigma 24-70f2.8
gasrocks Cream of the Crop 13,432 posts Likes: 2 Joined Mar 2005 Location: Portage, Wisconsin USA More info | Dec 16, 2010 15:31 | #2 |
xarqi Cream of the Crop 10,435 posts Likes: 2 Joined Oct 2005 Location: Aotearoa/New Zealand More info | Dec 16, 2010 15:33 | #3 I'm struggling to see a relationship here.
robtaylor22 Senior Member 425 posts Joined Nov 2010 Location: Utah More info | Dec 16, 2010 15:35 | #4 For the most part yes, but the 24-70 does allow you to go to F/2.8 which allows you to use a wider aperture and less fill flash vs. available light, 1 full stop more than the 24-105. Flash will negate the benefit of the 24-105's IS to some degree. If you are shooting a lot indoors aperture matters and the larger and heavier 24-70 will probably be a better fit, but for a walk around lens the 24-105 can't be beat. Just depends on what you need and mostly shoot.
AlanU Cream of the Crop More info | Dec 16, 2010 15:39 | #5 24-70L = pleasant creamy bokeh. It fails in reach compared to 24-105L 5Dmkiv |5Dmkiii | 24LmkII | 85 mkII L | | 16-35L mkII | 24-70 f/2.8L mkii| 70-200 f/2.8 ISL mkII| 600EX-RT x2 | 580 EX II x2 | Einstein's
edrader "I am not the final word" More info | Dec 16, 2010 15:40 | #6 L.Morey wrote in post #11464529 Will the 24-105 f4 do as good a job with indoor flash as the 24-70 f2.8 i'd say the biggest difference is the 24-70L focusses better in low light but either would be fine. http://instagram.com/edraderphotography/
xarqi Cream of the Crop 10,435 posts Likes: 2 Joined Oct 2005 Location: Aotearoa/New Zealand More info | Dec 16, 2010 15:40 | #7 robtaylor22 wrote in post #11464592 For the most part yes, but the 24-70 does allow you to go to F/2.8 which allows you to use a wider aperture and less fill flash vs. available light... The ratio of fill to available is dictated by the flash power, not the lens aperture.
xarqi Cream of the Crop 10,435 posts Likes: 2 Joined Oct 2005 Location: Aotearoa/New Zealand More info | AlanU wrote in post #11464617 24-70L = pleasant creamy bokeh. It fails in reach compared to 24-105L ed rader wrote in post #11464621 i'd say the biggest difference is the 24-70L focusses better in low light but either would be fine. ed rader Help me out here - how do these relate to flash?
Frugal Senior Member 784 posts Joined May 2009 Location: Northern CA More info | The ratio of fill to available is dictated by the flash power, not the lens aperture. Yes but for a given shutter speed you can shoot in a 1 stop darker ambient with f/2.8 vs f/4. - provided the DOF works for you Richard
edrader "I am not the final word" More info | Dec 16, 2010 16:09 | #10 xarqi wrote in post #11464628 The ratio of fill to available is dictated by the flash power, not the lens aperture. i usually try to shoot f5.6ish with flash indoors. http://instagram.com/edraderphotography/
Player9 Senior Member 658 posts Joined Mar 2007 More info | Dec 16, 2010 16:10 | #11 In some situations, the best lighting comes from bouncing the flash and allowing the bounced light to be the only light contributing to the exposure. In these situations, the faster lens doesn't help at all because it will need to be stopped down to make sure that none of that crappy orange light infects the nice clean light from the flash. RP, 60D, RF 24-105mm f/4-7.1 IS, RF 35mm f/1.8 IS, RF 50mm f/1.8, EF-S 10-22mm f/3.5-4.5, EF-S 18-135mm 3.5-5.6 IS, EF-S 55-250mm f/4-5.6 IS, Tamron 17-50mm f/2.8, EF 28mm f/1.8, EF 50mm f/1.8, EF-S 60mm f/2.8 macro, EF 85mm f/1.8, El-100, 430ex, 220ex, Alien Bee B400 (2), Alien Bee B800 (2)
V-Wiz Goldmember 2,255 posts Joined Sep 2009 Location: Southern California More info | Dec 16, 2010 16:14 | #12 Ive shot at f8 with flash indoors with great/sharp results. With a 24-105. Gripped 5D Mark II l 24-105 F/4 L l 70-200 F/4 L l Tokina 12-24 F4 l 50mm 1.8 l Sigma 600 Mirror l B+W KSM CPL l B+W 6stop ND filter l Hitech 0.6 GND l YN-468 Flash l Kenko Pro 300 1.4 TC l Induro Tripod, Vanguard 250 Ballhead.
Zigot Senior Member 602 posts Likes: 4 Joined Jun 2008 Location: Ottawa Ontario CAN More info | Dec 16, 2010 16:24 | #13 I'd go with the 24-105L. 7D2, 5Diii, 5Div, 70-300L, 24-105L, 70-200Lii, 100-400Lii, 135L, 430EXii, 580EXii, Σ50, Σ60-600 Σ150 Macro, ΣEM-140, LensBaby 3G, White lightnings, Bowens. Gear - feedbacks
TooManyShots Cream of the Crop 10,203 posts Likes: 532 Joined Jan 2008 Location: NYC More info | Dec 16, 2010 16:36 | #14 Permanent banFrugal wrote in post #11464747 Yes but for a given shutter speed you can shoot in a 1 stop darker ambient with f/2.8 vs f/4. - provided the DOF works for you But the point is moot once flash is involved. You can either drag the shutter or using a higher ISO to allow more ambient light to fill. One Imaging Photography
JeffreyG "my bits and pieces are all hard" More info | Dec 16, 2010 16:41 | #15 If the room is small I will usually light the whole room with the flash. In this case I typically use f/5.6 or so and thus the lighter weight and greater range of the 24-105 is preferred. My personal stuff:http://www.flickr.com/photos/jngirbach/sets/
| Latest registered member is semonsters 1024 guests, 106 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
