Thread started 17 Dec 2010 (Friday) 10:13
Question about a monopod
TijmenDal
Dec 17, 2010 10:13 |  #1
Hello there,
I'm in dire need of either a mono- or tripod. Now, I'm just a dirt-poor student so money is quite a problem (too bad :( ). Now, I was looking and stumbled upon this little baby here (external link) and the reviews are all very positive. It sounds good and I like that it's light and small. I don't plan on using it for wildlife or whatever, just so I can take a nice stable shot.
Pretty much what I'm asking for is if anyone has experience with this monopod, or if someone has a good alternative, which can be a tripod too. I have a feeling that a quality tripod is múch more expensive than a quality monopod (like the one I linked to?)
EDIT: Here a little extra info on the monopod:
http://www.velbon.co.u​k/newvelbon/pages/mono​pods.html (external link)
Regards!
//Tijmen
http://www.flickr.com/​photos/tijmendalexternal link
Gear
______________
flickrexternal link
_____________
lindsaytblum
Dec 17, 2010 10:23 |  #2
I recommend the Manfrotto 679B Monopod (external link). You can get it for around $50 on amazon. Also, you would want to get a head to connect your camera to the monopod. While it is not required, it is very helpful. I have the Manfrotto 234RC (external link). Having a head allows you to pan, tilt, etc.
Best,
Lindsay
Canon 7D | 24-70mm f/2.8L II, 135mm f/2.0L, 100mm f/2.8L IS USM, 85mm f/1.8
Portfolio (external link)
TijmenDal
Dec 17, 2010 10:38 |  #3
lindsaytblum wrote in post #11468907 (external link)
Best,
Lindsay
Thanks for the response! Problem is still my budget. The Velbon monpod is just 20 quid, while your setup is 90$, quite a difference, and not totally in my budget to be honest.
Also, the minimum height of 65cm is way too large for my liking. I'd like to fit it in my backpack, which won't be possible with the Manfrotto monopod, I know it's much better than the velbon one, but it doesn't quite fit my requirements. I'd just like a word of approval from someone that knows something about monopods as I have no clue whatsoever about them. I wouldn't really know what is important about a monopod except that the locking mechanism works (which it does seeing the positive reviews).
//Tijmen
Gear
______________
flickrexternal link
_____________
Sledhed
Joined Jun 2005
Dec 17, 2010 12:09 |  #4
TijmenDal wrote in post #11468851 (external link)
A monopod will not help with this. It will only stop motion in one direction, which is up and down. A monopod is used for one thing and that's to hold up a heavy lens.
Chris
Gear List | Website (external link) | Sports Sample Pictures (external link) | Four Seam Images (external link)
If you’re good at something, never do it for free. - The Joker
RPCrowe
Joined Nov 2005
Dec 17, 2010 14:27 as a reply to  @ Sledhed's post |  #5
I don't know about...
I don't know about the used market in the UK but, here in the states, tripods and monopods often do not hold their value on the used market. The result is that they are often quite good buys on eBay or some such web site. You might check your local eBay and if you have a Craigslist, check that also...
crn3371
Dec 17, 2010 15:54 |  #6
You need a tripod, not a monopod. Monopods are generally used with longer, heavier lenses as an extra means of support. Your 18-55 is neither long nor heavy. Either work on your hand holding technique and avail yourself of the IS, or get a tripod for shots requiring a longer shutter speed than is possible handheld.
Manix90
Dec 18, 2010 17:47 |  #7
would 300mm be long enough to require a monopod? Would a monopod be sufficiant if a tripod is impractical?
The Site (external link)
Jon
Joined Jun 2004
Dec 18, 2010 18:40 |  #8
Yes, and No. A monopod will give you a stop or two more leeway than hand-holding; but it's no substitute for a tripod once you get much below 3 stops slower than the advisable hand-held speed (1/f.l., and if it's a "crop" body, figure in the "crop factor" on the f.l.).
Jon
Cocker Spaniels
TijmenDal
Dec 19, 2010 15:25 as a reply to  @ Jon's post |  #9
I was mainly thinking of using it to make photo's like this one:
http://c0003976.cdn2.c​loudfiles.rackspaceclo​ud.com …2008/09/simondu​montnz.jpg (external link)
Now of course I don't expect them to be as nice, but I figured that when making a picture like that it's important the background doesn't shift, otherwise you can't layer them properly.
//Tijmen
Gear
______________
flickrexternal link
_____________
L.J.G.
"Not brigth enough"
Dec 19, 2010 15:28 |  #10
Sledhed wrote in post #11469491 (external link)
Yep. You still need a fast shutter speed using a monopod with a long lens. If you want slow shutter speeds get a tripod.
Lloyd
Never make the same mistake twice, there are so many new ones, try a different one each day
Gear Flick (external link)r
Jon
Joined Jun 2004
Dec 19, 2010 17:52 |  #11
TijmenDal wrote in post #11480026 (external link)
For that you absolutely need a rock-solid tripod and head combination. A monopod won't cut it.
Jon
Cocker Spaniels
SkedAddled
Gallery: 16 photos
Dec 19, 2010 22:27 |  #12
What Jon said.
Also, there's no way you can replicate the photo composite you posted without an understanding
of some sort of decent photo-editing software and multiple fast-rate exposures.
You'll most certainly need a good tripod for that sort of shooting, as well as some familiarity
with some darkroom techniques or a software program to replicate the effect. Also consider
some sort of remote which allows fast-frame shooting without your fingers contacting the camera,
as this can eliminate shake induced by physical contact.
Craig5D4|50D|S3iS|AF:Canon 28-135 USM IS|MF:Tamron SP 28-80|Tamron SP 60-300|Soligor 75-260|Soligor 400|Soligor C/D 500|Zuiko 50 f/1.8|others
Support this exceptional forum
Of course I'm all right! Why? What have you heard?!?
TijmenDal
Dec 20, 2010 01:24 |  #13
SkedAddled wrote in post #11482164 (external link)
What Jon said.
Thanks guys! So pretty much I'm gonna need a 200€ at least to make something like that (and a camera with more fps)? I'm good enough with photoshop to make something like that, just wondering about the pictures itself.
//Tijmen
Gear
______________
flickrexternal link
_____________
Jon
Joined Jun 2004
Dec 20, 2010 07:45 |  #14
200€ will be a minimum. As far as fps - how long do you figure that guy's air time was? Even the 1D3 or 1D4 can only handle 10 fps, so unless he was up for around 2 sec., you'd have trouble catching that many intermediate stages. The other thing to consider is the camera's buffer - for a contrasty situation like that you might need RAW; in any event you'd need a camera with a big enough buffer to handle the total jump time plus a bit on either side.
Jon
Cocker Spaniels
Beau1k
Dec 20, 2010 21:57 |  #15
HA! You need a tripod man!
7D - Transcend 32GB 600x - 70/200 IS II & 17-55 - Dolica Proline Carbon Fiber
5,527 views & 0 likes for this thread, 11 members have posted to it.
1059 guests, 104 members online
