Thread started 19 Dec 2010 (Sunday) 02:36
Zeiss 21mm with 5DII micro-adjustments
jlvpeng
Dec 19, 2010 02:36 |  #1
For those who has a 5DII, do you do micro-adjustments with the Zeiss 21mm when using it?
I haven't done it. But I am wondering if its worth the time to do it.
My Gear List and Market Feedback
http://www.jlvpeng.comexternal link
FuturamaJSP
Dec 19, 2010 02:42 |  #2
Well I don't have a Zeiss lens, yet but I have tried MA some Canon FD lenses and it actually turned them into the most accurate and fastest focusing lenses I have ever seen much faster and accurate than Canon EF lenses with USM.... :rolleyes:
They asked me how well I understood theoretical physics. I said I had a theoretical degree in physics. They said welcome aboard! - Fallout New Vegas
blah blah blah
DA (external link)
rvdw98
Dec 19, 2010 03:01 |  #3
I doubt that will happen with the Zeiss, as it's a manual focus lens. :D
Roy
NatDeroxL7
Dec 19, 2010 03:30 |  #4
If AF Confirm is giving you consistently the same wrong answer, I guess it could work.
If you use EG-S screen then nope, no point doing MA. Unless you are MAing your EYE.
https://www.instagram.​com/nd14411 (external link)
https://natedphoto.myp​ortfolio.com/ (external link)
Fodowsky
Dec 19, 2010 06:34 |  #5
I checked mine when I rented the Lens Align. The AF Confirm was dead on.
Gear and Feedback
jantzer
Dec 19, 2010 11:11 |  #6
If you can't get in-focus 21ZE shots you have your head where it doesn't belong. It's hard to take out of focus shots with it, unless you're shooting at 2.8 with close subjects, which is not it's intended purpose.
Gear: 5D2, S95, Tamron 28-75, 35L, 135L
jetcode
Dec 19, 2010 14:34 |  #7
bannedPermanently
The 21 has enough DOF to pretty much eliminate focus confirmation all together. Sharp as a tack and easy to focus. Great lens.
Mike ­ K
Joined Apr 2001
Dec 19, 2010 14:39 |  #8
Fodowsky wrote in post #11478102 (external link)
Calibrating MA will work correctly with MF lenses like Zeiss ZE lenses. As noted above it calibrates the focus confirm feature, which lights up when holding down the AF back button and turning the focus ring.
Obviously for a manual focus lens, Live View 5-10X is much, much more accurate than focus confirm, and thats the comparison that should be used to set MA.
Mike K
Canon 6D, 1DmkII, IR modified 5DII with lots of Canon L, TSE and Zeiss ZE lenses
jetcode
Dec 19, 2010 15:00 |  #9
bannedPermanently
Mike K wrote in post #11479811 (external link)
Obviously for a manual focus lens, Live View 5-10X is much, much more accurate than focus confirm.
Mike K
So much so I will no longer purchase adapters with focus confirmation. It's a complete waste of money.
jdizzle
Darth Noink
Dec 19, 2010 15:02 |  #10
Mike K
I agree. No need to MA a lens if you use LV.
1,835 views & 0 likes for this thread, 9 members have posted to it.
Latest registered member is Sandro Bisotti
1686 guests, 167 members online
