Thread started 19 Dec 2010 (Sunday) 09:51
Photoshop CS5 Cropping/Undo Crop
johnaengus
Dec 19, 2010 09:51 |  #1
I'm new to CS5. If I crop an image and decide to undo the crop or change it, how do I do this? I'm used to Lightroom, but can't figure out how to change my mind in PS.
finndogphoto.com
5Dmkii, 16-35 2.8L, 35 1.4L, 50 1.2L, 85 1.2L, 24-105 4L, 70-200 2.8 L IS, 580 EXII
sempaidavid
Dec 19, 2010 10:01 |  #2
press control Z
5D mkIII, 1D mkIV, Tokina 16-28 f/2.8, EF 24-70L, EF 70-200 f/2.8L II IS, EF 100-400L, EF 85 f/1.8, Sigma 50 f/1.4, EF 24-105
http://www.davidcostap​hotography.com (external link)
James ­ Salenger
Dec 19, 2010 10:02 |  #3
edit>undo crop.
I may not be the village idiot, but I'll do until
he gets here.
drvnbysound
Dec 19, 2010 10:04 |  #4
CTRL+Z (undo) ??
Or if it were done a number of steps ago, go to the history panel and click on the action before the Crop.
I use manual exposure settings on the copy machine
..::Gear Listing::.. --==Feedback==--
...A few umbrella brackets I own...
Olly_K1
Dec 19, 2010 10:09 |  #5
CTRL Z (Undo) Will work, but I normally use ALT + CTRL + Z to step backwards
foureightysix photography (external link) | Flickr (external link)
Canon 1D MKIV | Tokina 11-16mm f/2.8 | Canon 24-70mm f/2.8 L | Canon 70-200mm f/2.8 L |Canon 400mm f/5.6 L | Canon Speedlite 430EX II
LiberationFrequency
Joined Jun 2010
Dec 19, 2010 10:10 |  #6
I personally would modify the canvas size and resize the layer independently of the image size as to maintain the entire image.
Non-destructive editing is the way to go. But control/command + Z is the undo command. If it doesn't do it, look in the history panel for it.
Rayk
Gallery: 271 photos
Dec 19, 2010 10:11 |  #7
Try here (external link), here (external link) or here. (external link)
Regards Ray
LRPS - Licentiateship of The Royal Photographic Society- CPAGB - HON CPE - ACA - Adobe Certified Associate
www.rakphotographic.co​m (external link)
Follow me on Facebook (external link)
Ugly ­ Joe
Dec 19, 2010 12:11 as a reply to  @ Rayk's post |  #8
I'm hoping someone will correct me if I'm wrong, but I don't believe the file history is saved after you save and close a file in Photoshop.
So, if you've already cropped, saved, and closed the file, there's no way to undo that crop once you've closed it in CS5.
I believe Lightroom tags changes onto the file without actually changing it, whereas Photoshop is an actual change to the data file itself. This means changes can be undone, even after a save in Lightroom (I know that's how Adobe Camera Raw handles the files - I believe Lightroom uses the same method).
"Hell is an eternity of getting up at 4am to nothing but decaf coffee..."
A good friend will help you move.
A true friend will help you move a body.
An old friend more than likely will pass on either because of a bad back.
sempaidavid
Dec 19, 2010 12:14 |  #9
Ugly Joe wrote in post #11479180 (external link)
True. You always crop in ACR through Bridge. That's what I do. It works just like LR.
René ­ Damkot
Dec 19, 2010 12:15 |  #10
Cmd+Z will only work as long as the crop is still in the history. If you saved and closed the image after cropping, there's no undoing of a crop possible (unless you used the "hide" option)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
LiberationFrequency
Joined Jun 2010
Dec 19, 2010 12:18 |  #11
Yeah, LR uses non-destructive editing, and rather caches changes to be applied to a raw file instead of changing the actual file itself.
Which is why, when editing in photoshop, it is a good practice to be as non-destructive as possible.
Image -> Canvas Size and modify it into the end size you want
Then transform the layer as needed into the new canvas size.
If you really want to be smart about it, create a smart object out of a linked file...
René ­ Damkot
Dec 19, 2010 12:58 |  #12
No need to use the "canvas size" workaround.
Tick this when cropping (not available for images that only have a "background" layer):
IMAGE: https://img.skitch.com/20101219-kcxaafsynanpxdcc4nrp9seqws.jpg
To "undo" the crop go view > reveal all (that will show all the pixels that aren't empty, as would a smart object) or Canvas size > enlarge to whatever you want.
drvnbysound
Dec 19, 2010 13:10 |  #13
It is true that LR does a non-destructive crop, but that's only internal to LR anyway. You would have to export it as a JPEG to get it on the web, or to send off to photo lab. Fortunately, yes, you can go back into LR and remove the crop if you want and re-export. The problem I have with using LR to crop, is that there are times I need to make adjustments in PS, and dont want to have to export to PS, and back to LR just for cropping.
For this reason alone, I usually do all my edits, save a copy (usually the .psd so I can make future changes w/o having to do all the prior stuff again, and all the adjustment layers are still there), then crop, make changes to the image size (CTRL+ALT+I, to change resolution if needed), then "Save As" a .jpeg.
This may not be the best approach, but it's how I've been handling this problem for a while now.
johnaengus
Dec 19, 2010 13:43 |  #14
Thanks for the tips everyone. I got the picture. It seems that it would make sense to have a "copy" before the cropping like LR within the PS file.
finndogphoto.com
tonylong
...winded
Gallery: 60 photos
Dec 19, 2010 13:56 |  #15
Yup, always keep a copy of the original -- of course, if you're working out of LR it keeps the original and opens a copy in Photoshop. At that point, if you are doing "serious" editing, at some point it can pay off to save a tiff "project file" that includes basic stuff and then Save As stuff for the final output.
I myself prefer cropping in Lightroom/ACR but otherwise would tend to follow what I laid out above.
Tony
18,719 views & 0 likes for this thread, 13 members have posted to it.
1214 guests, 185 members online
