Thread started 19 Dec 2010 (Sunday) 17:19
Lightroom - batch crop & resize
Createsean
Dec 19, 2010 17:19 |  #1
I would like to be able to set up a preset that will batch crop and resize photos to 800x480 to put on my digital photo frame. I tried setting up an export option and resize to 800x480 but all the pictures ended up being 720x480 which is not what I want. I suspect it has something to do with the original aspect ratio.
Is there any way to set up a batch crop on export? if not it seems like a serious oversight on Adobe's part.
I'm looking for harsh criticism of my photos - tell me how to improve, I will be grateful.
My Gear | My web development business Caffeine Creations (external link) | flickr (external link) |My Photo Blog (external link)
Gatorboy
Dec 19, 2010 17:26 |  #2
Crop one image to your 8 x 4.8 ratio and then SYNCHRONIZE all the rest of the images selecting the Crop option. Then your export routine will work.
Dave Hoffmann
Createsean
Dec 19, 2010 17:28 |  #3
Gatorboy,
Thanks. But won't that leave them in my catalogue cropped like that? I'd prefer to keep them at full size.
tonylong
...winded
Gallery: 60 photos
Dec 19, 2010 18:24 |  #4
For that type of "special output" I use virtual copies. So, you select all the images, right-click and create virtual copies, then you can crop one and then sync to the rest. Export with that preset you have and that does the trick.
In other words, you are correct that the Export function won't crop to the different aspect ratio, but can resize to another aspect ratio -- if you tell it to not preserve the aspect ratio, but in that case you are likely to get some unpleasant and unwanted results.
Tony
Createsean
Dec 19, 2010 18:38 |  #5
ah.. virtual copies - I assume that it would be relatively easy after creating the virtual copies and cropping/resizing and outputting to delete all virtual copies
tzalman
Fatal attraction.
Dec 19, 2010 18:40 |  #6
Tony - I don't think you can. LR has no "constrain aspect ratio" checkbox because that's what it always does.
Createsean - So what? They are not really cropped, they are only "virtual crops" that can be changed or cancelled entirely at any time.
Elie / אלי
tzalman
Fatal attraction.
Dec 19, 2010 18:45 |  #7
Createsean wrote in post #11481007 (external link)
It's easier to delete the crops. If you do as Gatorboy said, crop one and synchronize the others, then all you have to do is the reverse, reset the crop on one and synchronize the others.
Elie / אלי
tonylong
...winded
Gallery: 60 photos
Dec 19, 2010 20:25 |  #8
tzalman wrote in post #11481025 (external link)
Ah, OK, I'm away from my photo workstation, I guess I mixed up LR with a "normal" resize!
To the OP, there is the option, the alternative to the virtual copy, to do like the below and it should be painless. You can undo the crop -- I'd say a quick way of doing that is to do the cropping last, make sure the aspect ratio is what you need it to be (fits the image export size aspect ratio), sync and Export, then go to the History panel in the Develop module, click below the crop, then Sync. If your processing on the images is different, you just click to check none then check the crop option.
Tony
Createsean
Dec 19, 2010 23:06 |  #9
Thanks for the tips everyone. I'll go with the crop, sync export, uncrop sync.
tonylong
...winded
Gallery: 60 photos
Dec 20, 2010 01:27 |  #10
Cool! The "Raw workflow" is a bit "different" from working in "normal' image editors...
Tony
René ­ Damkot
Dec 20, 2010 04:47 |  #11
tonylong wrote in post #11480920 (external link)
1) You can crop to whatever aspect ratio you like in LR.
2) The Export function doesn't "crop", but it can "resize". The resizing will maintain the aspect ratio the images was cropped to. In other words: You cannot "distort" (stretch) the image.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
7,116 views & 0 likes for this thread, 5 members have posted to it.
2877 guests, 135 members online
