Ever since I've had the Canon 7D I would use one of the many focal points with spot focus when I shot wide open on the 50mm lens. Well I always noticed a shift in focus when I shot wide open. Yet when I performed a focus test using the center focal point it turned out perfect. Well I was looking in C.Fn III: Auto focus / Drive on the 7d and noticed that the "Spot AF" was NOT selected. So when I was shooting wide open I was really never using Spot AF even though I had the metering mode set to spot focus. When the lens was wide open it would sometimes lock to something close to my focal point. With the SPOT AF enabled in custom functions this should fix the problem.
I haven't had a chance to give it a good test since I found this out.
