Thread started 21 Dec 2010 (Tuesday) 05:11
does the manfrotto 498RC2 have a bubble ?
mantra
Dec 21, 2010 05:11 |  #1
Hi
i'm looking for the net about this head and a bubble
i did not find pictures to know if this head has a bubble
may someone tell me ?
in the manfrotto site there is nothing about it
http://www.manfrotto.c​om …_/Midi_Ball_Hea​d_with_RC2 (external link)
and may i mount on a 190Xprob ? i mean in the manfrotto homepage there is that this head is perfect with the 055 line
thanks
cheers
canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
3 analogic Hasselblad and 2 anologic Mamiya
LittleFish
Dec 21, 2010 05:18 |  #2
I am thinking of buying this head, and to the best of my knowledge, I don't think it has a bubble level.
|Canon T1i | 50 1.8 | 18-55 IS | 17-55 IS USM | Manfrotto 190XPROB and 498RC2 |
-Syed-
lannes
Dec 21, 2010 07:01 |  #3
The 190xprob already has a bubble level on the tripod,
IMAGE: http://i81.photobucket.com/albums/j226/lannes2007/190xprob-1.jpg
The 498rc2 will work with the 190xprob.
mantra
Dec 21, 2010 07:51 as a reply to  @ lannes's post |  #4
i worried that only the 488RC4 has a bubble
http://www.manfrotto.c​om …-Holds_17.6_lbs.%288kg%​29 (external link)
it uses a 410PL Quick Release Plate
don't know the differents between the 498RC2 vs 488RC4 ...
mantra
Dec 21, 2010 08:02 |  #5
LittleFish wrote in post #11489815 (external link)
sadly i guess you are right
http://www.youtube.com …PNQ4NC5vQ&featu​re=related (external link)
SkipD
Joined Dec 2002
Dec 21, 2010 08:51 |  #6
DO NOT consider any of the Manfrotto RC4 quick release systems for EOS cameras. The quick release plate for the RC4 system is huge and not something that is conducive to handheld use of the cameras or lenses with the RC4 plates attached. The RC2 system, on the other hand, uses a much smaller quick release plate which most of us leave permanently attached to EOS bodies and lenses which have tripod rings on them.
Forget the bubble level as being a deal-breaker for any head. If you truly need a level for your camera, get one that slips into the hotshoe. There are also ways to prove that the camera is level without even using a spirit level.
Skip Douglas
mantra
Dec 21, 2010 10:03 |  #7
SkipD wrote in post #11490484 (external link)
thanks a lot for the RC4 !
so the solution is only the rc2 but i can't understand why manfrotto doesn't offer a hear with a bubble (is a lot more comfortable)
lot's of other brand made head like the 498rc2 with a bubble
but so i can not use no flashgun
often i use a flashgun like master to use the others flashguns
thanks
appreciate your help
mantra
Dec 21, 2010 10:58 |  #8
lannes wrote in post #11490087 (external link)
are you sure the 190xprob has a bubble ? in the manfrotto ,in the specs there is not bubble feature
LittleFish
Dec 21, 2010 15:57 |  #9
http://www.youtube.com​/watch?v=X-6wW1XC_Ko (external link)
look at 0:45 (:
-Syed-
Blurr ­ Cube
...a lucky id-iot that didn't get electrocuted...
Dec 21, 2010 17:00 as a reply to  @ LittleFish's post |  #10
Looking at mine (498RC2 head)... nope. My 055XPROB does however. ;)
| Canon EOS Systems |
lannes
Dec 21, 2010 19:29 |  #11
mantra wrote in post #11491076 (external link)
If you look at the spare parts list, part R190,507, you will see a bubble level.
http://mediacdn.shopat​ron.com …B_20090310.pdf?​1272346402 (external link)
http://www.manfrottosp​ares.com …uct&path=1&prod​uct_id=939 (external link)
It looks like it does in all the pictures I've seen.
http://www.amazon.com …_images_3?ie=UT​F8&index=3 (external link)
SkedAddled
Gallery: 16 photos
Dec 21, 2010 22:29 |  #12
The 488 head does not include a bubble level. At least, mine does not have one.
I'm fairly certain that the newer 498 head also does not include a bubble level.
lannes has pointed out that the 190XPROB legset includes a bubble level,
and I'll confirm that the 055XPROB set also includes one.
Skip mentions a very good point, regarding size comparisons of the RC4 and RC2
quick-release systems. The RC4 plate is a huge thing to have mounted to a camera
or lens, while the RC2 plate is, comparatively, much smaller. I have several RC2
plates, permanently attached to my camera and lenses with a tripod mount, and they
do not get in the way of my use of them during handheld situations. It is also a very
stable and secure system when used properly.
Craig5D4|50D|S3iS|AF:Canon 28-135 USM IS|MF:Tamron SP 28-80|Tamron SP 60-300|Soligor 75-260|Soligor 400|Soligor C/D 500|Zuiko 50 f/1.8|others
Support this exceptional forum
Of course I'm all right! Why? What have you heard?!?
mantra
Dec 22, 2010 01:03 |  #13
Blurr Cube wrote in post #11493079 (external link)
thanks!
sad it has not a bubble
in a review i read that the head 498RC2 has a system that can be used to to level the head to have precision, accuracy in the landscape or architecture, architectonics,shootin​g
but in the review there is nothing more detailed
can't understand manfrotto , what could cost (in $) add a bloody bubble in the dead
thanks a lot
cheers
mantra
Dec 22, 2010 01:12 as a reply to  @ mantra's post |  #14
is there a head similar, analogue to the 498rc2 with a bubble?
Gizto is manfrotto ,and they have a head with a bubble
is there some good alternative?
lannes
Dec 22, 2010 04:42 |  #15
Lots of ball heads have bubble levels.
Really Right Stuff
http://reallyrightstuf​f.com …x?code=Ballhead​40&key=cat (external link)
Markins
http://www.markinsamer​ica.com/MA5/category.p​hp?req=1 (external link)
Photo Clam
http://photoclam.en.ec​21.com …ead--4521671_4521680.html (external link)
Vanguard
http://www.vanguardwor​ld.com …all+and+Pan+hea​d-145.html (external link)
Slik
http://www.thkphoto.co​m …ts/slik/slik-SBH-320.html (external link)
Slik are dumb enough to have 2
IMAGE: http://i81.photobucket.com/albums/j226/lannes2007/IMG_9564.jpg
17,606 views & 0 likes for this thread, 11 members have posted to it.
1053 guests, 103 members online
