Thread started 21 Dec 2010 (Tuesday) 19:39
getting lens to shoot at full 250mm @ moon
TeleFragger
Dec 21, 2010 19:39 |  #1
Ok so i took my t2i out and fired away.. tried Av and couldnt get them to come out not washed out..
so off with the search feature.. it schooled me on what i was doing wrong..
i had F7.1 - 250mm - iso 200 - 2 seconds.... oops there i found it..
so learned that i need to shoot M
I did
1/160
F/8
ISO - 100
but it will only go to 146mm
if i send it to 250.... and focus it zooms back out....
so i tried manual focus....
what am i doing wrong??
thanks guys... getting ready for the next moon wave (think googling said end of january)....
this pic is cropped WAY OUT... as it was really small @ 146mm
GearBag - Feedback****Flickr - my playhouse (external link)****RF-603 Discussion
Canon 7Dm2 Gripped | 32GB Transcend CF | 64GB Toshiba FlashAir | YN-468 Flash | YN-468 II Flash | RF-603 | EF-S 18-55 IS|EF 24-105L|EF 50 MKII 1.8|EF-S 55-250 IS |EF 85 1.8| Tamron SP 70-200mm f/2.8 Di VC |Primo's Trigger Stick Monopod | Manfrotto Carbon Fiber Tripod
if I post a pic.. it is there to be picked on... (I have thick skin.. im in IT)
chris ­ jones
Dec 21, 2010 23:00 |  #2
Manual is a must.. if your camera has live view, use that and you can zoom in further to make sure the focus is perfect. Use mirror lockup, and a self timer if you don't have a remote. At that focal length, keep your exposures short (less than 2 seconds). After that, focus on the post processing.. sharpen the photo, reduce noise if necessary, adjust levels. Hope this helps
kjonnnn
Dec 21, 2010 23:13 |  #3
While rules can be broken, But start from the Sunny 16th rule for shooting moon.
"F16 and Use a that Shutter Speed equals or near your ISO." Start there and adjust your shutter speed.
So if you're shooting ISO 100. Use F16 with Shutters Speed of 1/100 or whatever your camera has. Adjust SSpeed as necessary to get the right exposure.
And yea, you'll probably have to manual focus, depending on what focal length your lens is at 250mm
MT ­ Stringer
Dec 21, 2010 23:23 |  #4
I don't understand this statement at all. The camera can't automatically adjust the zoom. That's the little ring you turn. Maybe you are confused or got your terms mixed up.
Just remember the moon is lit by the sun so your exposure could be similar to a shot taken in your back yard in the afternoon.
Something like this...
Info
Canon 40D, Sigma 120-300 f/2.8 plus Sigma 2x TC = 600mm
ISO 400, 1/125ss, F/7.1 Manual camera control and manual focus using Live View.
(DUPLICATE IMAGE)
MaxPreps Profile (external link)
My Gear List
SteveInNZ
Dec 22, 2010 00:19 as a reply to  @ MT Stringer's post |  #5
When the lens does a big hunt from one end of the focus travel to the other, it does kind of look like it's zooming if you're using live view and it's trying to set the exposure at the same time. I'm guessing it's something like that anyway.
+1 for the rest of the answers.
No need to use mirror lockup if you're using live view as the mirror is already up.
Steve.
"Treat every photon with respect" - David Malin.
TeleFragger
Dec 22, 2010 04:32 |  #6
well here is a really newbish question... live view... anotherwards focus through the back lcd vs looking through the hole???
ill give all these a try tonight... and yes.... during the focusing.. it appears to zoom in and out... i zoom it all the way out and when i go to focus.. it searches.. locks.. and 5 pics all said @ 146mm
thanks... ill test it out tonight...
mtbdudex
Gallery: 35 photos
Dec 22, 2010 08:17 as a reply to  @ TeleFragger's post |  #7
I have T1i, prior had the 55-250 lens you have, it can take pretty decent full moon shots.
a) Full moon settings @ 250mm: Manual mode ISO100, f11, 1/250 sec.
Even less than full moon @ 250mm I usually dial open the aperture slightly first, then the shutter speed slightly. Always underexpose the moon so not to blow out the highlights. Keeping shutter relatively fast will keep pict sharp.
b) Use Live view for focus, 10x, move the box to contrasty portion of moon and press the *, it will zap focus and go green box
c) Tripod is best if you have one
d) wireless timer is best, else use the 2 sec delay self timer or the up to 10 picture multi timer, set it to 2 and it will countdown 10 seconds, this way camera is still.
e) turn IS off
Have fun, good luck, post results.
Mike R, P.E. ...iMac 27"(i7), iPad2, iPhone14Pro, AppleTV4K, MacBook
Canon: Body R5, lens RF 24-105mm L F4, RF 100-500mm f/4.5-7.1L, 1.4 TC, EF 70-200 L f2.8 IS II / TC 1.4x 2x
FEISOL tripod CT-3441S + CB-40D Ball Head
My top 10 in Astrophotography. . .DIY acoustic panels (external link) . . APOD Aug-5-2011 (external link)
TeleFragger
Dec 22, 2010 08:29 |  #8
mtbdudex wrote in post #11496371 (external link)
think my problem lies within here...
ok live view... moon filled up the entire view.... 10x??? not following that part....
press * (is that the shutter button? dont remember seeing a * icon anywhere).... will zap focus.. so lens in manual focus or auto?
Thanks... and yeah i will post results.. once i can get this dialed in!!!!!!!!!! Appreciate it all....
MT ­ Stringer
Dec 22, 2010 10:50 |  #9
ok live view... moon filled up the entire view.... 10x not following that part....
Read the section on Live View in your users manual. No manual- download it from the Canon USA website.
If you switch your lens to "M", and adjust the focus "manually" you won't have the wild gyrations. That is why it is important to use the Live View feature. The instructions will explainhow to zoom the view to 5x or 10x. Then you can focus a lot easier. Then back the zoom view out to normal and take your picture.
I say shoot everything on manual. Don't be skeered! :-)
My Gear List
TeleFragger
Dec 22, 2010 10:59 |  #10
MT Stringer wrote in post #11497099 (external link)
HAH thanks.. ill give it a try... however my son is in a xmas choir tonight... so may not get to try tonight...
I was shooting in M.... but the live view i was mistaken.. though that was just hitting the button and seeing it out back.... but im misconfused!!!! :lol:
mtbdudex
Gallery: 35 photos
Dec 22, 2010 16:45 as a reply to  @ TeleFragger's post |  #11
I believe to get into Live view you hit the red dot.
To select between normal/5x/10x you hit the white checker 9 box button, to use contrast focus use the * button.
I actually focus in 10x and even shoot the shot in 10x, does not hurt anything.
IMAGE: http://www.kenrockwell.com/canon/images/t2i/t2i-back-1200.jpg
This is 10/22/2010 full moon with my T1i + 55-250 @ 250, using 1/250 sec, ISO100, f11, yours should be even sharper with 18MP vs 15MP.
(exif data is in pict)
IMAGE: http://lh3.ggpht.com/_FqTNmgNQHz8/TMLREdE7sKI/AAAAAAAALFI/9KkAvb6Yfvc/IMG_8537.jpg
InfiniteGrim
Joined Nov 2010
Dec 23, 2010 00:21 |  #12
I see you commented on my picture.
This is exactly what I used.
T1i
55-250mm @ 250mm
First and foremost I used a tripod and turned IS off. I zoomed all the way in on the moon, and made sure the moon was on the center dot and had the camera focus. Then I turned it to manual focus.
Several days ago I got a great shot @
ISO 100
F/11 (all of my sharp shots with surface detail was with F/11)
1/60 - 1/100
Then for the Lunar eclipse I used the same settings but I couldn't get a good sharp shot. Its important to note that only 1-2 shots out of 5 shot at the above settings came out clear.
Because my previous settings were failing me I tried a large range of ISO 100-800 and shutter speeds from 1/60 - 1/800. Oddly I got sharp results with many different settings, but only 5-6 really good shots out of 100+ different configurations.
First is
ISO 400
F/11
1/800
IMAGE: http://i56.photobucket.com/albums/g165/InfiniteGrim/Lunar%20Eclipse%202010/IMG_0020.jpg
Next was
For some reason this part of the moon doesnt have craters that are very large or visible so not many photos of the moon in this position will have surface detail unless your lens gets closer.
ISO 200
F/11
1/400
IMAGE: http://i56.photobucket.com/albums/g165/InfiniteGrim/Lunar%20Eclipse%202010/IMG_0137.jpg
Here are the first picture I took with
ISO 100
F/11
1/60
IMAGE: http://i56.photobucket.com/albums/g165/InfiniteGrim/Lunar%20Eclipse%202010/IMG_1686.jpg
Above but closer
IMAGE: http://i56.photobucket.com/albums/g165/InfiniteGrim/Lunar%20Eclipse%202010/IMG_1686-1.jpg
IMAGE: http://i56.photobucket.com/albums/g165/InfiniteGrim/IMG_0620.jpg
hollis_f
Dec 23, 2010 05:47 |  #13
InfiniteGrim wrote in post #11501104 (external link)
Unless you're using a remote shutter release I would definitely leave IS on. Even with a remote release I'd probably leave it on for two reasons -
1. Unless you've got a really good tripod it's likely that there will be some small movement. The IS will compensate for that.
2. The IS on the 55-250 can sense when it's on a tripod and disable iteself, if necessary.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
syndicate1
Joined Nov 2010
Dec 24, 2010 13:02 |  #14
Instead of just answering a simple question, you go out your way to respond to a thread, only to say go read your manual? I hope you are not a school teacher, because you sure don't know how to pass on knowledge
Geez
TeleFragger
Dec 24, 2010 13:46 |  #15
syndicate1 wrote in post #11508692 (external link)
Geez
actually something so simple.. i did go download it and readup some... seems simple...yes i should have done that first.. but i did search here first... but i was looking more for the specifics on people with the nifty two fifty that have shot the moon..
appreciate it all folks... still havent had a chance to get back out there...
happy holidays!!!!!!!!!! now we got tons of people coming over.... :cool:
10,022 views & 0 likes for this thread, 9 members have posted to it.
1040 guests, 114 members online
