Picture North Carolina wrote in post #11498525
Thanks for the feedback.
No, don't register publishing-related shoots. I figure after the piece is published, because of subject matter the pics are never useful to me again.
Ah, but you don't register just because you think the images will be useful, you register to protect your intellectual property. Images that are going to be widely published are far more likely to be infringed, and when your images are infringed, a registered copyright often means that you are going to get paid something, often quite a lot of something. This assumes that the infringement takes places in America, of course.
I could be wrong, and have not looked into it yet, but as I understand it small claims now goes up to about $7500. And as I mentioned, as I understand it you still cannot sue for lost labor in SCC - so the actual material losses would most certainly be under 7.5k.
Small claims maximums vary by local jurisdiction. If you'd registered your copyrights, you wouldn't need to do this in small claims, you could likely hire an attorney on contingency who would negotiate a settlement that might be quite a bit higher than the small claims maximum.
I really need to make a big long post called "Register your damned copyrights" and try to get it stickied. There is a general ignorance of how important it is to register your copyrights. This is best practices stuff here, and if you're not doing it, you're leaving yourself open to being taken advantage of by less-than-honest publishers.
