nikmar08 wrote in post #11499177
Did you happen to check the lens archive threads?
I look at the lens archive thread far more often than any reasonable person should. It's 388 pages with thousands of images. It isn't really a realistic task to look at them all, check the Exif info, and save the ones I want to compare later. I know this only because of the ridiculous amounts of time I've spent looking.
Not that I am a pro or veteran in this field but the general tip I have got to minimize that effect is to widen the aperture and to remove any "cheap" filters while taking pictures pointing straight into high-lit sources of light. Now as in your case, the apertures values seem to be fairly narrow, it would be interesting to hear what others have to say... especially if it's something about the 17-55 as I am planning to buy one soon.
Thanks, but what I'm trying to see is if the 17-40 specifically will perform better at small apertures. The 17-55 and 10-20 are great lenses, and I have not found flare to be a big problem with either one during general use. There are many times, however, that I want to shoot at f/14 or smaller at night with 30 second or longer exposures when street lights are prominent in the frame. It's really a very specific situation and can't be used to evaluate any lens' overall performance.
Here's the 17-55 at f/11 for 9 seconds:
Here it is at f/13 for 22 seconds. The aperture is smaller, the exposure is longer, and the lens is much closer to the lights. The flare is also noticeably worse. I'm just wondering if a 5D + 17-40 combination would handle similar situations better.
| HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
Oh, and you can take a look at my
17-55 sample
gallery to see the general type of photography I do with this lens. It is definitely a very capable lens.
