Doctorh --
I've tried to make minor adjustments to both of these. Take a look and see if you think these would be any improvement.
For the church I mostly corrected perspective, which also resulted in cropping the image a bit. That's about all I could think of to do with it.
For Red Square I adjusted white balance and made a very minor perspective correction, and then cropped the right side just a little, which I think improved the composition. There does seem to be a little detail in the sky. You might be able to bring that out a little with some effort. (I didn't try; with a small jpg I was afraid all it would do is posterize.)
I admire you for getting out and fighting the elements! I've hardly taken any pictures the last few weeks, and the weather hasn't been nearly that bad here.
