Mvan wrote in post #11509354
Mr.Talzman,
Here is a update.
- I can download my pictures to my HD useing EOS software.
- Tried import my pictures into LR3.3 by move them from the HD into LR3.3 but that did not work come up with a error(Could not move files requested to new location.)
- Then I tried importing my picture from my HD by using the add button in LR3.3 inport and that did work.
Mark
Mvan, you have to understand that you cannot move photo files "into" LR. LR consists of a data base catalog(s), which is essentially just a text file with very sophisticated indexing, and two preview caches. The photos are always somewhere on your hard drive in a location that you determine, not "in" LR. If you ask LR to move or copy a photo to a new location, it does two things. First it sends a command to Windows to do the actual move/copy and second it updates the entry in its catalog regarding the location of the photo. So, if moving, either from card to HD or from one spot on the HD to another, fails and importing without moving ("Add") is successful, it sounds like one of two possibilities is happening - either user error in that you are not correctly designating a destination for the moved file or a Windows 7 error. Since you said you have no problem with an XP machine the finger seems to point at Win 7.
The work-around will be to always do what you did: to move the files with EOS Utility and then import to LR using "Add". (I, BTW, always do that myself because I prefer the facilities for viewing files on the card before moving them afforded by a program called BreezeBrowser Pro to those of LR.)
