About to buy a tilt shift.
I shoot architecture and real estate. And that's pretty much it.
Don't really feel like investing in new filters, since the only one I use is a polarizer with my 17-40. Not in the mood to spend a ton on 82mm, but:
I have heard that 24mm is better for interiors.
Problem is, I use a 5d and a 1d3...
What I'm asking is: Is the 17 'too' wide for interiors? There might be some distortion on the 5d (e.g. stretched corners) but I'm assuming I can crop this if necessary. I am thinking that the 17 will be perfect on the 1d3 to remove some of that stretched look if it comes to it.
Would there be a change in 'perspective' or 'view' from using the 17 and then cropping, in such a way to make the 24 better for my purposes? Or am I way overthinking this, and should I just go with the 17 for better compatbility with both my bodies? 24mm on APS-H isn't really wide enough at all.
I think I just answered my own question, but I still felt the need to ramble incoherently! Thanks
Any opinions would be appreciated.
Buying the wrong lens would be a lot cheaper than renting.
