Swift wrote in post #11512937
Hello,
Could you please list me some lens that will do better than the 18-55mm f/3.5-5.6 without IS? (The lens that came with my Rebel XT) Should I just get the new kit lens with the IS?
Budget: <$400However you can mention other lenses too if you'd like. I'll create a poll for everyone to vote on once I have enough suggestions...
hhhmmmm... well, the one with IS would fare better than the one without simply because at 55mm your widest apeture is 5.6...without IS, and in lighting anything other than full bright sunshine, you'll have to use a slower shutter or higher ISO (or both). Darker than Dusk, a tripod will be a must, or you'll just end up with blurry pics.
So, less than $400? Go with the IS version of the same lens. It should only be about $150/200.
As I see it though, your real options (if you want to "add" a little bit of potential opportunity) are either:
a) EF 28-135mm f/3.5-5.6 IS USM $479.99 , or
b) EF-S 18-135mm f/3.5-5.6 IS $499.99 , or
c) EF-S 18-200mm f/3.5-5.6 IS $699.99
but in the end, I'd suggest you save for a bit, and increase your budget to $1000. You wouldn't regret it. In that case I would easily suggest :
EF 24-105mm f/4L IS USM $1,249.00
