I don't know how to edit to save my life.
![]() | HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by FLICKR |
Can someone give me some tips on what I should be the rules/step of editing/touch ups? Thanks in advance.
DownsPhotography Goldmember 1,967 posts Likes: 1 Joined Mar 2010 Location: New Orleans More info | Dec 26, 2010 10:49 | #1 I don't know how to edit to save my life.
Can someone give me some tips on what I should be the rules/step of editing/touch ups? Thanks in advance. | 5D mark III | 5D mark II gripped | Canon 100L |Canon 24-105L | Canon 70-200L 2.8L IS II | Sigma 35 1.4 | Sigma 50 1.4 | Sigma 85 1.4 | 580ex II | 430ex II x 2 |
ChasP505 "brain damaged old guy" 5,566 posts Likes: 1 Joined Dec 2006 Location: New Mexico, USA More info | Dec 26, 2010 10:59 | #2 Downs Photography wrote in post #11516211 I don't know how to edit to save my life. You underrate your skill. I would adjust the color temperature of the first shot a bit... It seems a little cold. Some simple lighting or bounced flash could have helped with the shadows on the children's heads. Chas P
PixelMagic Cream of the Crop 5,546 posts Likes: 6 Joined Nov 2007 Location: Racine, WI More info | Dec 26, 2010 11:17 | #3 Neither photo needs much editing. You can use Photoshop 's Shadow/Highlight command to lift the shadows in the first photo then warm it up a bit by adjusting the color temperature.
Sorarse Goldmember 2,193 posts Likes: 25 Joined Jan 2008 Location: Kent, UK More info | Dec 26, 2010 11:18 | #4 Without knowing what you want to achieve with the finished image, it's difficult to advise what you need to do with regard to editing. At the beginning of time there was absolutely nothing. And then it exploded! Terry Pratchett
Kolor-Pikker Goldmember 2,790 posts Likes: 59 Joined Aug 2009 Location: Moscow More info | Dec 26, 2010 11:20 | #5 ChasP505 wrote in post #11516251 You underrate your skill. I would adjust the color temperature of the first shot a bit... It seems a little cold. Some simple lighting or bounced flash could have helped with the shadows on the children's heads. +1 5DmkII | 24-70 f/2.8L II | Pentax 645Z | 55/2.8 SDM | 120/4 Macro | 150/2.8 IF
BestVisuals Senior Member 763 posts Joined Apr 2007 More info | I love your images. Canon 5D MK II, 24-105 L, Sigma 16mm fisheye
DownsPhotography THREAD STARTER Goldmember 1,967 posts Likes: 1 Joined Mar 2010 Location: New Orleans More info | Dec 26, 2010 11:37 | #7 ChasP505 wrote in post #11516251 You underrate your skill. I would adjust the color temperature of the first shot a bit... It seems a little cold. Some simple lighting or bounced flash could have helped with the shadows on the children's heads. I used two umbrellas both @ a angle of 90 degrees on each side. Thanks for the tips tho PixelMagic wrote in post #11516342 Neither photo needs much editing. You can use Photoshop 's Shadow/Highlight command to lift the shadows in the first photo then warm it up a bit by adjusting the color temperature. The second photo probably only needs a different crop and/or a vignette to hide the kid in the background and bring the attention to the infant. What's on the little girl's front teeth? Thanks again. I will try that Sorarse wrote in post #11516347 Without knowing what you want to achieve with the finished image, it's difficult to advise what you need to do with regard to editing. usally when I try to edit pictures people be like you could have done this etc. so I take it my editing game is lacking. Kolor-Pikker wrote in post #11516353 +1 The reds/purples are a bit too strong. I would also use an adjustment to even out the background a little. Thanks man BestVisuals wrote in post #11516359 I love your images. You'll need an image editor no matter how good you are. No matter what you do, do NOT buy Photoshop unless you're willing to take a class to use it. Get Photoshop Express or any of the other consumer-based editors. Too many options and choices can frustrate you. I used to use PhotoImpact for professional editing, and it cost less than the TAX you pay to buy Photoshop, and did more for my work than PS did...one-click color correction, fixed cropping sizes, layers, animation, etc.,...all things PS forgets to do easily. I bought photoshop cs5 a few months ago. I usually go in adobe bridge and load up camera raw and mess with the vibrance then go to the adjustment tool clarity +50 to the eyes and -50 to the skin to smooth it out. After that I use spot remove or whatever its called to remove scars etc. after that I have no idea what to do. Thanks btw | 5D mark III | 5D mark II gripped | Canon 100L |Canon 24-105L | Canon 70-200L 2.8L IS II | Sigma 35 1.4 | Sigma 50 1.4 | Sigma 85 1.4 | 580ex II | 430ex II x 2 |
TeleFragger Goldmember 3,188 posts Likes: 219 Joined Aug 2010 Location: Williamstown, NJ More info | Dec 26, 2010 11:38 | #8 BestVisuals wrote in post #11516359 I love your images. You'll need an image editor no matter how good you are. No matter what you do, do NOT buy Photoshop unless you're willing to take a class to use it. Get Photoshop Express or any of the other consumer-based editors. Too many options and choices can frustrate you. I used to use PhotoImpact for professional editing, and it cost less than the TAX you pay to buy Photoshop, and did more for my work than PS did...one-click color correction, fixed cropping sizes, layers, animation, etc.,...all things PS forgets to do easily.
GearBag - Feedback****Flickr - my playhouse
BestVisuals Senior Member 763 posts Joined Apr 2007 More info | Dec 26, 2010 11:47 | #9 Gosh - I' like the photos! You've very good at lighting! Downs Photography wrote in post #11516421 I used two umbrellas both @ a angle of 90 degrees on each side. Thanks for the tips tho Thanks again. I will try that usally when I try to edit pictures people be like you could have done this etc. so I take it my editing game is lacking. Thanks man I bought photoshop cs5 a few months ago. I usually go in adobe bridge and load up camera raw and mess with the vibrance then go to the adjustment tool clarity +50 to the eyes and -50 to the skin to smooth it out. After that I use spot remove or whatever its called to remove scars etc. after that I have no idea what to do. Thanks btw these are some images I editing using all the information I like to you. Yall let me know what yall think. Thanks in advance http://www.downsphotography.com/p948206569 Canon 5D MK II, 24-105 L, Sigma 16mm fisheye
DownsPhotography THREAD STARTER Goldmember 1,967 posts Likes: 1 Joined Mar 2010 Location: New Orleans More info | Dec 26, 2010 12:00 | #10 ChasP505 wrote in post #11516251 You underrate your skill. I would adjust the color temperature of the first shot a bit... It seems a little cold. Some simple lighting or bounced flash could have helped with the shadows on the children's heads. I warmed it up some and noticed the big differance. Thanks again PixelMagic wrote in post #11516342 Neither photo needs much editing. You can use Photoshop 's Shadow/Highlight command to lift the shadows in the first photo then warm it up a bit by adjusting the color temperature. What's on the little girl's front teeth? She has silvers, cause she ate to much candy
after editing | 5D mark III | 5D mark II gripped | Canon 100L |Canon 24-105L | Canon 70-200L 2.8L IS II | Sigma 35 1.4 | Sigma 50 1.4 | Sigma 85 1.4 | 580ex II | 430ex II x 2 |
Kolor-Pikker Goldmember 2,790 posts Likes: 59 Joined Aug 2009 Location: Moscow More info | Dec 26, 2010 12:09 | #11 Are you sure you won't poke anyone's eyes out with those reds? Can't focus on the children when I have red in my face. 5DmkII | 24-70 f/2.8L II | Pentax 645Z | 55/2.8 SDM | 120/4 Macro | 150/2.8 IF
PixelMagic Cream of the Crop 5,546 posts Likes: 6 Joined Nov 2007 Location: Racine, WI More info | Dec 26, 2010 12:17 | #12 After you use the Shadow/Highlights tool you need to mask off the kids so the adjustment only affects the background. Right now everything is adjusted equally.
ChasP505 "brain damaged old guy" 5,566 posts Likes: 1 Joined Dec 2006 Location: New Mexico, USA More info | Added some warmth and selective sharpening. Just guessing at skin tones on these beautiful children. Chas P
DownsPhotography THREAD STARTER Goldmember 1,967 posts Likes: 1 Joined Mar 2010 Location: New Orleans More info | Dec 26, 2010 14:23 | #14 ChasP505 wrote in post #11516903 Added some warmth and selective sharpening. Just guessing at skin tones on these beautiful children. Hosted photo: posted by ChasP505 in ./showthread.php?p=11516903&i=i63007604 forum: RAW, Post Processing & Printing Nice work. Plz explain the skin tones and how youi did it. | 5D mark III | 5D mark II gripped | Canon 100L |Canon 24-105L | Canon 70-200L 2.8L IS II | Sigma 35 1.4 | Sigma 50 1.4 | Sigma 85 1.4 | 580ex II | 430ex II x 2 |
rw2 Goldmember 4,201 posts Likes: 3 Joined Jun 2006 Location: North Dakota More info | Dec 26, 2010 15:00 | #15 thought I would give the second pic a shot. Not sure this is any better than your edit. If you're afraid of failure ... you'll never succeed!
| Latest registered member was a spammer, and banned as such! 2915 guests, 138 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
