Thread started 27 Dec 2010 (Monday) 12:09
Markins Q10 locked up in low temp??
ddong
Dec 27, 2010 12:09 |  #1
Markins Q10 locked up at low temp (-15°C or below)? I found mine has this issue. I wonder if anybody else found this problem?
bohdank
Dec 27, 2010 12:14 |  #2
I haven;t used it below -4c and haven't had any problems.
One thing to keep in mind is that if you bring it out of a warm environment, set it up, quickly, the ballhead will still be cooling and, therefore, shrinking, which could account for the lockup. I don't think it would be a lubricant.
I find lenses don't AF properly until their temperature has stabilized, in cold weather.
ddong
Dec 27, 2010 14:16 |  #3
WD-40 will help? say, drop 1 or 2 before I use it at really cold environment?
sheawyatt
Dec 27, 2010 14:46 |  #4
No high-end ballhead should not require ANY lubricant (especially WD-40). Bohdank's suggestion is probably the right one. Or just send an email to Markins and see what they have to say.
EOS R5 | RF 15-35 f/2.8 | RF 24-70 f/2.8 | RF 70-200 f/4 | EF 400 f/4 DO II | EF 1.4x III |
Marketplace Feedback: Link
www.sheawyatt.ca (external link)
JohnJ80
Dec 27, 2010 16:59 |  #5
I use mine in the cold all the time. Are you sure that you don't have the friction control set too tight?
J.
Obsessive Gear List
"It isn't what you don't know that gets you in trouble; it's what you know for sure that isn't so." - Mark Twain
res
Dec 27, 2010 21:28 |  #6
sheawyatt wrote in post #11523236 (external link)
I have their Q20 and never had that problem. Shot last winter in 0 degrees farenheit with 25 mph wind. It never locked up. They were good folks when I dealt with them for the purchase. I would drop them an email.
Kasrielle
Gallery: 88 photos
Dec 27, 2010 22:16 |  #7
My Photo Clam froze up while I was shooting the eclipse - but not until it had been out in -25C for almost 2 hours...
www.photosbykas.com (external link)
my Flickr Page (external link)
500px.com/Kasrielle (external link)
ddong
Dec 27, 2010 23:41 |  #8
JohnJ80 wrote in post #11523968 (external link)
J.
no friction control set at all because I knew it'll lock up fast if I do.
ddong
Dec 28, 2010 15:36 |  #9
Tried WD-40, it helped a lot.
From Markins manual:
" 5. Apply about 3 drops of WD-40 to the ball"
" ... ... Before going out to the field in cold weather, cleaning can enhance trouble-free operation and prevent from getting moisture and freezing."
afoton
Joined Apr 2012
Dec 11, 2012 04:43 |  #10
ddong wrote in post #11522323 (external link)
I have a Q3T, and that one also lock up in the cold. I can't manage to adjust the friction controll limiter with mittens, so the head is totally unusable in the winter.
Phrasikleia
Dec 11, 2012 04:53 |  #11
Yes, I had a Q3 lock up on me in -11C the other day. I keep a little aluminum screwdriver in my bag for these sorts of occasions (to get the friction limiter unstuck).
Photography by Erin Babnik (external link) | Newsletter (external link) | Photo Cascadia Team Member (external link) | Facebook (external link)
René ­ Damkot
Dec 11, 2012 06:57 |  #12
Never had the issue, then again, I didn't do many hours of shooting below freezing.
Phrasikleia wrote in post #15352294 (external link)
Shouldn't need a screwdriver. Just tighten the main knob and the friction limiter will unstick.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
peter_n
Dec 11, 2012 07:03 |  #13
Markins manuals now come with brief instructions on a ball cleaning routine that will "enhance trouble-free operation and prevent from getting moisture and freezing". Apparently a thin film of WD-40 on the ball is the key.
~Peter
Phrasikleia
Dec 11, 2012 07:25 |  #14
René Damkot wrote in post #15352496 (external link)
Hmm. Really? I once got the thing so jammed that I had to abandon a shoot because I couldn't use the ball head. That's what made me buy the little lightweight screwdriver to keep in my bag. Maybe it didn't occur to me to try to tighten instead of loosen. I'll have to to try that and see if you're right!
afoton
Joined Apr 2012
Dec 11, 2012 07:36 |  #15
The problem with that little thumb screw and low temperature, is that I have mittens on my hands. So the little screw is out of reach (without freezing my fingers).
peter_n wrote in post #15352509 (external link)
That doesn't work for me. The head doesn't work in the cold (when it is dark, and I really need a good tripod)
3,875 views & 0 likes for this thread, 11 members have posted to it.
1320 guests, 120 members online
