Thread started 28 Dec 2010 (Tuesday) 08:34
cranberry bread
cp1005
Dec 28, 2010 08:34 |  #1
What can I do in photoshop to make the background here whiter? (I tried adjusting the white balance but that didn't work.) Thanks in advance......
IMAGE: http://farm6.static.flickr.com/5206/5298284001_214bed5b98.jpg
IMAGE LINK: http://www.flickr.com …/36657249@N08/5​298284001/  (external link)
TTk
Dec 28, 2010 08:35 |  #2
Yum! Yum!..
Terry.:cool:
http://www.terrykirton.co/ (external link)
http://www.ttkphotogra​phy.com/ (external link)
http://www.langtoftpho​tography.com/ (external link)
 (external link)
TTk
Dec 28, 2010 08:40 as a reply to  @ TTk's post |  #3
Like this?
Quick selection tool, then feather 1px, used Levels.;)
Terry.:cool:
 (external link)
vpnd
Dec 28, 2010 10:47 |  #4
the challenge for food photography..... make people want to eat it and youve done it. I almost want to eat that. WB is a little funky.
Canon "Snappy".... Thanks Mom and Dad!
"I don't like to play dress up, or pet my gear. I like to shoot stuff and then print it and put it on my wall."
cp1005
Dec 28, 2010 16:10 |  #5
Thanks vpnd!
vpnd wrote in post #11528294 (external link)
Thanks TTK!
TTk wrote in post #11527555 (external link)
Yum! Yum!..
Thanks for the help!
How;s this?
IMAGE: http://farm6.static.flickr.com/5205/5301514230_eabd0bc6b7.jpg
IMAGE LINK: http://www.flickr.com …/36657249@N08/5​301514230/  (external link)
Peano
Dec 28, 2010 16:25 |  #6
The white dropper defaults to 255.255.255. I would set it lower, maybe 242.242.242. The bread could also use some sharpening.
IMAGE: http://img207.imageshack.us/img207/2214/bread.jpg
Peano
RadiantPics.com (external link)
cp1005
Dec 28, 2010 16:30 |  #7
Peano wrote in post #11530214 (external link)
can you explain please? "the white dropper"? ( I am using CS2) THanks!
cp1005
Dec 28, 2010 16:50 as a reply to  @ cp1005's post |  #8
played around with another shot--c + c appreciated!
IMAGE: http://farm6.static.flickr.com/5289/5301030569_4dab5aaef0.jpg
IMAGE LINK: http://www.flickr.com …/36657249@N08/5​301030569/  (external link)
Peano
Dec 28, 2010 16:56 |  #9
cp1005 wrote in post #11530235 (external link)
In either levels or curves, there are three droppers. The white one sets white point and defaults to 255.255.255.
Double-click the dropper and a color picker will open. Change the brightness value to 95%. That'll make the RGB values 242.242.242.
Click OK to close the color picker, then click the white dropper on the background above the bread.
IMAGE: http://img141.imageshack.us/img141/3465/dropper.jpg
Peano
cp1005
Dec 28, 2010 17:04 as a reply to  @ Peano's post |  #10
Thanks peano---you are being very helpful! If you don't mind another question tho :)
How do I keep the bread from getting to light when I use this color picker?
Peano
Dec 28, 2010 17:21 |  #11
cp1005 wrote in post #11530387 (external link)
If you use 95% brightness on the highlight dropper, you'll only get a little clipping (mostly in the red channel) on the bread. If you want to avoid even that, select the background, then open the curves layer and click the dropper. The selection will automatically create a mask on the adjustment layer when you open it. (By the way, always use adjustment layers for this kind of adjustment; never work on image pixels).
After you do the background, use the same mask inverted on another curves layer. That will mask out the background so you're only adjusting the curve on the bread.
If you're not up on adjustment layers, masks, color correction techniques, etc., then you should check some place like www.lynda.com (external link) or www.kelbytraining.com (external link) for tutorials.
Peano
1,030 views & 0 likes for this thread, 4 members have posted to it.
cranberry bread
2679 guests, 164 members online
