Thread started 28 Dec 2010 (Tuesday) 11:37
Practicing with new T2i on cat
TRACER
Joined Nov 2010
Dec 28, 2010 11:37 |  #1
Got a new T2i for Christmas and been practicing on the cat.
Other than the overblown background what else can be done to improve.
Used 18-55 kit lens and a little work in the software that came with the camera.
Any C & C is welcome.
Thanks,
Randall
Randall
7D,Tamron 70-300 F/4-5.6 Di VC USD; Canon 15-85
robertwsimpson
Joined Jun 2010
Dec 28, 2010 11:43 |  #2
looks soft, and I think your white balance is off. what were your camera settings?
Peano
Dec 28, 2010 12:21 |  #3
A reflector in front and a little to the right would have helped with shadow details in the face and also would have toned down the background some (because the brighter face would need a smaller aperture). Try a piece of white cardboard or even the dull side of a piece of aluminum foil. If Miss Kitty doesn't object, place it 18" or so from the face.
Peano
RadiantPics.com (external link)
TRACER
Joined Nov 2010
Dec 28, 2010 12:44 as a reply to  @ Peano's post |  #4
Thanks for the feedback.
Camera settings:
5.6
1/30
ISO 1600
Focal Length 55 mm
Shot Manual in RAW
The cause of the softness?
High ISO, quality of the lens, all of the above!
More likely my skills or lack thereof.
Randall
Peano
Dec 28, 2010 12:52 |  #5
TRACER wrote in post #11528972 (external link)
ISO 1600
Yikes! That makes no sense.
Peano
tcusta00
Dec 28, 2010 13:01 |  #6
Camera settings:
5.6
1/30
ISO 1600
Focal Length 55 mm
Shot Manual in RAW
If you're handholding and/or shooting a moving target like an animal you can't reliably have a shutter speed of 1/30 and eliminate motion blur. At least I can't. :)
robertwsimpson
Joined Jun 2010
Dec 28, 2010 13:14 |  #7
it's not super-noisy, so I wouldn't blame the high ISO. I'd say it's a combination of shooting at 1/30sec shutter and f/5.6... mainly the shutter speed. you definitely need to be faster than that (usual rule is shutter speed should be the inverse of the focal length, in your case ~1/60 of a sec.).
A better option would have been to turn around, use the light from the window to your advantage, and compose a completely new photo.
TRACER
Joined Nov 2010
Dec 28, 2010 14:15 as a reply to  @ robertwsimpson's post |  #8
"Yikes! That makes no sense."
Not sure what you mean on this statement, could you explain a bit.
Thanks.
Randall
Peano
Dec 28, 2010 14:32 |  #9
TRACER wrote in post #11529490 (external link)
Thanks.
Yes, with bright sunlight, you should be able to shoot at a much lower ISO. If you can't, then you need either fill flash or (as I suggested before) a reflector to get more of that sunlight on your dark subject.
Peano
robertwsimpson
Joined Jun 2010
Dec 28, 2010 14:36 |  #10
weird. I was going to suggest using ISO3200 and 1/60sec shutter.
TRACER
Joined Nov 2010
Dec 28, 2010 17:49 as a reply to  @ robertwsimpson's post |  #11
@Peano-Gotcha. Thanks.
Randall
Titus213
Dec 28, 2010 19:50 |  #12
There doesn't appear to be anything in focus in the image - a good indicator of camera shake.
And I think you've gotten the idea that you need some more light on the cat's face.
Dave
Perspiring photographer.
1,517 views & 0 likes for this thread, 5 members have posted to it.
887 guests, 130 members online
