Hello,
I've been reading the past topics but nothing really, from what I found, seemed to answer the following:
I'm going to be lighting a 15' wide x 8' deep area using 2 AB800's for a benefit. Myself and the other photographer will both be firing them using remote triggers.
My main questions is, what would be the best configuration to do this. I have some ideas, but I'm not sure which one is optimal. Here's what I've come up with so far:
1. Use my large (60"x40") soft-box directly over our heads at strip center (to light 7 1/2 feet on both sides) high up pointing down (set back maybe 10 feet max) and then using my medium (30" x 40") soft-box to use as a side light off to the right pointing toward the left side of the 15 foot strip (feathering somewhat)
2. Use a large umbrella on the left side, 45 degrees pointing toward the middle of the strip with the medium soft-box off to the right, at eye level (approx) to provide fill light.
That's kind of where I ended. So I'm looking for some advice on how to do this. I don't have a parabolic reflector, but can get a hold of large umbrellas if need be. The cameras can also be equipped with on camera flashes if need be.
Thanks for any advice!
