Thread started 28 Dec 2010 (Tuesday) 22:33
R1900 B&W Printing
canon ­ shooter
Dec 28, 2010 22:33 |  #1
Anyone else having issues printing B&W prints on the R1900?
Just can't seem to get a True Black and White print out of this printer. I know it is not known for it's B&W's but for glossy colors.
I printed some today and seem to have a color cast to me. Can't really post results as the image on monitor looks B&W.
Jim
5D Mark III Grip, 40D Grip, Canon 17-40L, Canon 24-105 F4L IS, Canon 70-200 IS II F2.8L, Canon 100-400L, Canon 50 F1.4, Canon 100 F2.8, Canon 580 EX
It's the Glass that Counts!
tonylong
...winded
Gallery: 60 photos
Dec 29, 2010 02:28 |  #2
Check the driver for B&W only prints -- you may have to select the printer doing the "color management" but of course B&W bypasses that...
Tony
tzalman
Fatal attraction.
Dec 29, 2010 03:38 |  #3
Just about everyone. The R1900 is well known for poor B&W. The problem is that the colors added to the basic CMYK(glossy)K(matte) are red and orange instead of a light black/grey ink. So the trade-off is a wide gamut in orange-red (wider than Adobe RGB) for poor B&W. If I want to do mono-tone I go to sepia.
Elie / אלי
canon ­ shooter
Dec 29, 2010 10:37 |  #4
tonylong wrote in post #11533269 (external link)
So are you saying in the printer set up dialog you are checking "grayscale"?? Do you see a difference by doing this??
Also are you saying you change to printer doing color management?? And if so what do you mean when you say "B&W bypasses that"?
Jim
tonylong
...winded
Gallery: 60 photos
Dec 29, 2010 12:12 |  #5
I'm just saying that with some printers you need to switch to the grayscale option or else you get a color cast. I don't have an R1900 so can't ssay for sure what will work best there but with the printer I use you need to do that to get a "true" B&W. Try a few things to see what works best.
Tony
canon ­ shooter
Dec 29, 2010 12:50 as a reply to  @ tonylong's post |  #6
Here are two scanned images of results from R1900.
They are not very good copies (poor scan quality) but the one o little girl on ground actually looks good B&W, and the other has color cast.
Well now I see when I preview the images scanned the one of girl standing does not have the color cast that the print shows.
NOW I AM REALLY CONFUSED
Jim
tzalman
Fatal attraction.
Dec 29, 2010 16:29 |  #7
On my screen the head and shoulders shot is neutral gray and the girl sitting has a cyan cast.
Elie / אלי
canon ­ shooter
Jan 04, 2011 22:38 as a reply to  @ tzalman's post |  #8
I did get some instructions from Epson that really made a Huge difference. Not perfect but very very close to calibrated monitor.
If anyone interested let me know and I can post.
Jim
sue.t
Gallery: 30 photos
Jan 04, 2011 22:45 |  #9
I'd be interested in those instructions from Epson. Always wanting to learn more regarding my R1900.
tzalman
Fatal attraction.
Jan 05, 2011 00:12 |  #10
Me too.
Elie / אלי
canon ­ shooter
Jan 09, 2011 10:46 as a reply to  @ tzalman's post |  #11
Sorry, I forgot to post the instructions from Epson.
My issue was I was get a strong color cast when converted to B&W. I was letting PS do color management and printing same as I would a color image. Here is what Epson said and it seems to work for me.
1. Open the image in Photoshop
2. Click File and select Print
3. Make all necessay changes in Photoshop Print Window. For Color Handling, slect Printer Manages Colors and Rendering Intent select Perceptural.
4. Click Print Settings in the Photoshop Print Window.
5. Select the Media Type and Size.
6. Click Advanced tab, since you are letting the printer handle the colors, in the Photoshop Print Window, for Color Management on the right select Photo Enhance and set Scence Correction to Gray.
7. Click OK and test the printer.
Worked for me, let me know if it help you as well.
Jim
Jimmer411
Thank god Im green.
Jan 09, 2011 13:30 |  #12
Did you desaturate the image to achieve B&W? I have zero issues printing B&W without a color cast on my R1900 without changing any settings from my normal every day printing.
I had issues with a blue tint on my first B&W but that was before I owned a Spyder3Elite. Is your monitor calibrated?
5D3 | Sigma 30mm f/1.4 HSM | EF 85mm f/1.8 USM | EF 24-70 f/2.8L II | EF 70-200 f/2.8L IS II | 430EX | YN-568EX II | YN-622c | YN-622-TX |
Selling Sigma 30mm 1.4
canon ­ shooter
Jan 09, 2011 15:31 |  #13
Jimmer411 wrote in post #11604920 (external link)
Yes my monitor is calibrated and I convert to B&W in CS5 using the adjustment layer for B&W.
The monitor and print out are now very very close without color cast.
Jim
ChasP505
"brain damaged old guy"
Jan 09, 2011 17:54 |  #14
How could the monitor profile cause a blue tint when printing? Even you see a blue cast on the screen, if the B&W is neutral (R=G=B), the print should be neutral.
Chas P
5,028 views & 0 likes for this thread, 6 members have posted to it.
R1900 B&W Printing
2753 guests, 138 members online
