Thread started 29 Dec 2010 (Wednesday) 12:39
7D review brightness bug?
Saxi
Dec 29, 2010 12:39 |  #1
I am running the latest firmware but something I have noticed a few times and caused me to take a second look.
I'll be shooting as normal and I look at the review image that comes up and it looks rather unexposed (guessing 1.5 stops) when I was previous shooting seconds before with almost perfect exposure in the same lighting. I go back and look at my images to make sure this wasn't happening to other images and the image is perfectly exposed.
It seems occasionally it will show an image underexposed during review, I can't put my finger on a pattern but I had it happen again to me shooting on Christmas. I was getting great exposures and all of a sudden one comes in 1.5 stops down, thinking I messed something up I press Play and go through my images and I don't see any issues. Go back to shooting and everything is fine again.
5D III, 24-105mm f/4 L, 135mm f/2 L, 70-200mm f/4 IS L, 580EX II
Full Gear List
Flickr Photostream (external link)
hieu1004
Dec 29, 2010 12:41 |  #2
I haven't noticed it with mine and I am on the latest firmware. Perhaps reload?
-Hieu
Gear | Blog (external link) | flickr (external link)
Saxi
Dec 29, 2010 12:47 |  #3
hieu1004 wrote in post #11535497 (external link)
I can try that, I've had it happen a few times. It probably happens every 5-6 times I go to shoot, maybe more maybe less and usually only once during that shoot.
I would think it is just me and my eyes playing tricks, but I have had happen so many times I really believe it is happening.
Full Gear List
David83
Gallery: 10 photos
Dec 29, 2010 12:54 |  #4
Saxi wrote in post #11535471 (external link)
i noticed mine doing that yesterday ...as soon as the pic is taken and displayed it appears to be way underexposed but not every pic is that way... but when i open it back up to check again it is fine:eek:
Canon EOS R3 / Canon EOS R5 / Canon EF 600mm F4 IS L II / Canon RF 400mm F2.8 IS L / Canon RF 100-300mm F2.8 L / Canon EF 300mm F2.8 IS II L / Canon RF 70-200mm F2.8L / Canon EF 85mm 1.4 L IS / Canon EF 8-15mm F 4 L / Canon RF 28-70 F2 L / Canon RF 24-70mm F2.8L / Canon RF 15-35 F2.8 L IS / Canon RF 50mm F1.2L
beerba
Dec 29, 2010 12:57 as a reply to  @ David83's post |  #5
Mine is working good. No misshapps sofar(5000 exp)
7D / 24-70 f:2.8L USM / EF300 f:4L IS USM / 16-35 f:2.8L II USM
TTk
Dec 29, 2010 13:02 as a reply to  @ beerba's post |  #6
Maybe the camera or card is not rendering the image quick enough, does this happen single shots or multi?
Terry.:cool:
http://www.terrykirton.co/ (external link)
http://www.ttkphotogra​phy.com/ (external link)
http://www.langtoftpho​tography.com/ (external link)
 (external link)
Saxi
Dec 29, 2010 13:04 |  #7
TTk wrote in post #11535681 (external link)
Usually single, I use low speed continuous 99% of the time but the shot that happened at Christmas was single shooting in low speed continuous but I snapped two exposures with two individual shutter clicks within a second or less of each other.
Full Gear List
jwcdds
Gallery: 1929 photos
Best ofs: 8
Joined Aug 2004
Dec 29, 2010 13:19 |  #8
I addressed this issue in another thread.
Basically, when you're taking a photo and have your face dead-smack in the back of the camera.. the ambient light sensor thinks you're in a dark room, therefore, the 2-second preview image will typically look darker (under exposed). But once you tap the review/playback button, when your face is no longer kissing the back of the camera where the sensor is... the LCD will adjust to the brighter ambient light and will often get you a brighter review image. That or just turn off "Auto brightness" and you won't have to deal with that problem (but then you'd have either too bright or too dim results when reviewing).
But... if that's not the problem you're having, and the images are actually coming out dark.. then well, your 7D has gone wonky.
Julian
apersson850
Obviously it's a good thing
Gallery: 35 photos
Dec 29, 2010 13:21 as a reply to  @ Saxi's post |  #9
We answered this question here two days ago, or so.
You have set your display to automatic brightness. When you take a picture, you face covers the brightness sensor at the back of the camera, and since the camera doesn't flicker back and forth with the brightness of the display, but keep it steady at the level that was appropriate when you turned it on (in this case at the moment when the picture was taken), the display will be pretty dim. When the review is over, and you press the "play" button, you normally don't have your face covering the brightness sensor. Instead, it's pretty likely that the back of the camera is facing the sky or lamps in the ceiling, and thus the camera cranks up the brightness.
You can easily test this by simply covering the brightness sensor when you press the "play" button. The image will look darker.
To circumvent this issue, press "play" then INFO until you see the histogram. It will properly reflect the brightness of your image, regardless of the brightness of the display.
Ha, Julian was one minute faster than me!
Happy New Year, folks!
Anders
Saxi
Dec 29, 2010 13:24 |  #10
jwcdds wrote in post #11535794 (external link)
That sounds like it could be the problem, but my face usually up to the camera when I hit review, maybe there is a lag sometimes. Would make sense that was it.
Full Gear List
Saxi
Dec 29, 2010 13:28 |  #11
apersson850 wrote in post #11535809 (external link)
yeah I got that from Julian and it makes perfect sense.
I use the histogram and keep this up as my default review. I can't remember but I believe the histogram looked fine when I saw it but wanted to figure out if anyone else had the same issue.
Full Gear List
AbPho
Sep 15, 2012 11:16 |  #12
I just posted this reply over on this thread. Might be related.
With my 7D the AUTO BRIGHTNESS no longer works. Except when I am in the menu adjusting the setting. At that point the ambient light level affects the LCD screens brightness. Once I exit out of the menu the brightness is locked in and never changes. I am not sure when this happened but it is recent. Wonder if it came with the v2.0.0 firmware upgrade.
Update: I found out that under changing ambient light levels the screens brightness only changes upon a screen refresh. So, you either durn the display OFF and ON with the INFO button, or preview an image with the PLAY button. Otherwise it won't change from it's current brightness setting.
I'm in Canada. Isn't that weird!
1,706 views & 0 likes for this thread, 8 members have posted to it.
2845 guests, 175 members online
