Been trying to get a decent image of this for months. Finally got some good data that captured some of the nebula in the arms of M33. Thoughts?
M33
Sullij Member 74 posts Joined Dec 2010 Location: Cali More info | Dec 29, 2010 22:52 | #1 Been trying to get a decent image of this for months. Finally got some good data that captured some of the nebula in the arms of M33. Thoughts? M33 Canon 1000D Kit lens 18-55 and EF 75-300. Look Up!
dugpatrick Member 38 posts Joined Oct 2008 More info | Dec 30, 2010 14:35 | #2 Very nice!!
tkerr Goldmember 3,042 posts Likes: 2 Joined Mar 2010 Location: Hubert, North Carolina, USA. More info | Dec 30, 2010 15:29 | #3 Still clipping the dark points too much. Doing so, you're also clipping away at faint details the extend out in the arms of the galaxy or even within the galaxy. You also might be removing other faint jewels in the FOV. Tim Kerr
Dec 30, 2010 18:29 | #4 tkerr wrote in post #11542898 Still clipping the dark points too much. Doing so, you're also clipping away at faint details the extend out in the arms of the galaxy or even within the galaxy. You also might be removing other faint jewels in the FOV. There is also no color whatsoever in the stars, and there is some red within the galaxy that looks as though it was added as an after thought to add some color to it. I also see you used two different exposures. You do realize that's not necessary and can actually do more harm than good. Stacking averages your exposures, and when you do that and can actually reduce your total cumulative exposure. (E.g 1x 3min 45sec (225sec) + 1x 3min (180sec) = 1x 3min 42.5sec (202.5sec) after being stacked together). if you're 225second exposures are good there is no reason to shoot anything shorter. There is no purpose for doing that, unless of course it's an object like the Orion nebula when you shoot different exposures and stack them separately for later blending in Photoshop; as in or similar to shooting HDR Images. I don't mean to seem so harsh or critical, but what I see you doing are the same mistakes I and many others have done also. Over clipping the dark points! Space is dark, not pitch black. And there are stars do have some color surrounding M33. It was on advice similar to what you're getting now that set me on the right track. Now I just need clear stable skies so I can get out and do some astrophotography myself before I forget how to. I would love to have a crack at your Stacked data before you put it into Photoshop. Hello Tim, Canon 1000D Kit lens 18-55 and EF 75-300. Look Up!
Dec 30, 2010 18:36 | #5 dugpatrick wrote in post #11542631 Very nice!! I'd like to capture M33, but it seems like the subs are very dim and I have problems capturing color correctly. How do you balance the color with the CLS filter? Are you using DSS or something else for the stacking? Doug Hi, Canon 1000D Kit lens 18-55 and EF 75-300. Look Up!
Dec 30, 2010 20:39 | #6 Sullij wrote in post #11543832 Hi, I stack with MaximDL and move straight to Photoshop. I did the custom white balance with a grey card for the CLS filter so later all I have to do is use the Photoshop Histogram, and Levels to balance the color. Later I will adjust to my taste and comparisons with other photographers with curves to arrive at a comprable image to most. Here are some comparisons: Canon 1000D Kit lens 18-55 and EF 75-300. Look Up!
tkerr Goldmember 3,042 posts Likes: 2 Joined Mar 2010 Location: Hubert, North Carolina, USA. More info | Dec 30, 2010 22:53 | #7 Sullij wrote in post #11544450 Here are some comparisons: For comparisons I will look at guys like Jerry Lodigruss Rogelio Andreo (Nebulas) and Tony Hallas, Both guys are Astronomy picture of the Day (APOD) winners, I will use them for models for my photos. Follow this link and mouse over Jerry's photo to see the IC Nebulas names and note the coloring, Mr Lodigruss has done our homework for us, Lodigruss site: http://www.astropix.com …M33_Triangulum_Galaxy.HTM Or Tony's Hallas photo here: http://www.astrophoto.com/M33.htm You can veiw tKerr's redition here: http://www.photoshop.com …eceb540de80e105068224099a Rogelio Andreo (nebula guy) http://blog.deepskycolors.com/ Checking out APOD and other web sites, or just searching through Google Images is a great assist. I often look around to compare what other people do with a certain DSO to see how it should probably look when I am done. But we also have to take into consideration the differences in cameras, Telescopes, mounts and experience. I try to look at the specs to see what people are producing with similar equipment. Trying to compare what I do or you do, and try to emulate it when the person you're comparing to is using much supperior equipment and has about 20 years or more experience than you is only going to get frustrating. Tim Kerr
Thanks for the advice. I will look for an upload site. Canon 1000D Kit lens 18-55 and EF 75-300. Look Up!
NovaTJ Senior Member 552 posts Likes: 1 Joined Jan 2009 Location: Stafford, Virginia More info | http://www.yourfilelink.com/ Astro-Tech 8" f/4 imaging Newtonian,Baader MPCC,Orion ED 80 APO F7.5,Skywatcher EQ-6 Pro,ASGT, Modified Canon 50D, Meade DSI Guide Camera, 8" SCT dovetail mounted relic, Criterion Dynascope RV-6, modified 300D, custom astro shed,and still just getting started!
Jan 01, 2011 16:22 | #10 Thanks and Happy New Year. Canon 1000D Kit lens 18-55 and EF 75-300. Look Up!
Ok Here ya go, this is the up load file link: Another rendition IMAGE LINK: http://www.flickr.com …/49217915@N04/5318824536/ another color variation Have Fun. Vacation is over time to go back to work. Best Canon 1000D Kit lens 18-55 and EF 75-300. Look Up!
tkerr Goldmember 3,042 posts Likes: 2 Joined Mar 2010 Location: Hubert, North Carolina, USA. More info | Jan 03, 2011 10:43 | #12 You didn't shoot any Flats with that, and the hot spot is making it hard to PP. Looking at the stars I am also seeing some collimation issues. I am seeing quite a bit of coma, and some that have that seagull look also. I will post my results with your image as soon as I get it reasonably presentable. Tim Kerr
tkerr Goldmember 3,042 posts Likes: 2 Joined Mar 2010 Location: Hubert, North Carolina, USA. More info | Jan 03, 2011 12:06 | #13 Are you shooting if full size RAW or did you reduce the size of the picture. Tim Kerr
tkerr Goldmember 3,042 posts Likes: 2 Joined Mar 2010 Location: Hubert, North Carolina, USA. More info | Jan 03, 2011 12:18 | #14 And another variation of it darker trying to correct for the hot spot. I could probably create a false flat, but even that won't correct for it as nearly as good as real flats.. Tim Kerr
foxtrot01 Member 164 posts Likes: 1 Joined Dec 2010 Location: New York, United States More info | Nice color!
| Latest registered member is Monkeytoes 1359 guests, 191 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
