Thread started 30 Dec 2010 (Thursday) 16:07
How to get 5 Exposures for HDR???
mypoppy31
Dec 30, 2010 16:07 |  #1
I've been shooting HDR with my Canon T1i camera. Normally I'd go to AEB and change the settings to all + and - 2, giving me Three exposures. One overexposed, the second medium, and the third one underexposed.
But, I understand that some HDR users are going for the FIVE exposures?..
I"ve checked out my camera, and simply can't find the way to get it to do
5 exposures for HDR. I've been using Aperture Priority..
Anyone know the solution?..
Thanks.
jwcdds
Gallery: 1929 photos
Best ofs: 8
Joined Aug 2004
Dec 30, 2010 16:18 |  #2
You can do 6-shot HDR. 2x brackets of 3.
Set it to 2/3 stop difference for the bracketing, adjust your EC to -1 stop initially. (So it takes -1, -1.66, -0.33.) Then swing the EC to +1 and take the next set of bracket. (So it then takes at +1, +1.66, +0.33.)
So all 6 shots are 2/3 stops apart.
Julian
johnknap
Dec 30, 2010 16:20 |  #3
Set your bracket +-1 then set exposure compensation +1. Shoot then repeat by setting exposure compensation to -1. A tripod will be needed of course
Heath
Joined Sep 2009
Dec 30, 2010 16:20 |  #4
Promote Control
Heath
"Some photographers push the envelope. Some sit behind a keyboard and criticize their accomplishments." (seen in the comments of a photo article)
Blog (external link)-Twitter (external link)-Zenfolio (external link)-500px (external link)-Pinterest (external link)-Gear List
MCAsan
Joined Jun 2010
Dec 30, 2010 16:24 as a reply to  @ jwcdds's post |  #5
I have done 9 shots for HDR by using +1, -1 and 0. But then use exposure compensation to move the "0" up and down a few more stops. Make sure everything is on manual so nothing encourages the camera to change something mid session.
Sam_M
Dec 30, 2010 16:38 |  #6
Or do five shots in all manual. That would be the easiest way without having to worry about bracketing.
Canon 50D | Nikon D850 D200
+ other assorted glass, plastic, and metal.
wookiee2cu
Dec 30, 2010 17:01 |  #7
+1 for promote remote. Especially if you do HDR pano's... huge time saver.
MattD
Dec 30, 2010 17:10 as a reply to  @ Sam_M's post |  #8
I take hdris for cgi - with the 5d 2 its posible to get a pretty massive range by setting up your c1-3 dial.
iv set mine up to take 9 shots, each image 2 stops apart, taking a total of 9 images.
the other options are "magic lanturn" firmware hack and the promote control.
Flickr (external link).
500PX (external link)
Tumblr (external link)
whchan
Dec 30, 2010 17:18 |  #9
Use manual mode. Just change the shutter speed accordingly.
cheezz
Dec 30, 2010 21:13 |  #10
Set C1 thru C3 for different exposures for HDR shots (temporarily or permanent, your choice) That way you have 9 shots. Going from C1 to C3 required only 2 clicks. Shooting 9 shots under manual requires a lot more clicks. Custom settings lesser chance of camera movement. Need tripod of course. JMO.
Canon 7D // EF 24-70mm f2.8L USM, EF 85mm f1.8 USM, 50mm 1.8 II Nifty Fifty, EF 28-135mm f3.5-5.6 IS USM kit lens, EF-S 55-250mm f4-5.6 IS, 430EX II
Added: EF-S 15-85mm f3.5-5.6
Added: EF 70-200mm f4L IS
Added: 1.4 II TC
mypoppy31
Dec 30, 2010 21:23 |  #11
cheezz wrote in post #11544635 (external link)
CHEEZ, could you please explain the C1, C2 ?...I'd really appreciate any help.
I'm using a Canon T1i SLR camera. I know I can use Manual or Aperture priority which I do, but I still don't know how I can get 5 or even 9 exposures with my camera.
Thanks,
highstakes
Dec 30, 2010 23:32 |  #12
C1, C2, and C3 are your custom user setting; they allow you to save shooting modes/functions...so you can switch between 3 saved settings instead of manually changing exposure/settings. Its nice to have, but I am not sure if the T1i has them or not.
Canon 5D II - Canon 16 - 35 f2.8L II - Canon 70 - 200 f2.8L IS II - 430EX II
Heath
Joined Sep 2009
Dec 30, 2010 23:38 |  #13
There are not any Custom Settings on the T1i.
Heath
cheezz
Dec 31, 2010 01:19 |  #14
diputs wrote in post #11545320 (external link)
Ah, so. My bad.
Added: 1.4 II TC
Edsport
Dec 31, 2010 07:11 |  #15
Manual mode is so easy to do as many as you want. You just move the dial to change the shutter speed...
Cameras - Canon 350D, 5D
Lenses - Canon 18-55mm, 75-300mm, 50mm f/1.8, 24-105L, 24-70L
Flashes - Yongnuo YN460 II, YN468
RF-602 transmitter and 2 receivers
4,454 views & 0 likes for this thread, 14 members have posted to it.
1118 guests, 171 members online
