I was in the same predicament as you were several years ago. After reading more reviews than I can remember, I bought the Tamron 28-75. I use it more than any of my lenses other than my macros and have been very pleased with it. Optically, it has performed very well, consistent with the reviews, which say that it is very close to the Canon except in the far corners, which you won't see with your crop sensor camera anyway. It lacks full time manual focusing, which I would like, and it is a bit annoying to have to remember to zoom in the other direction (but really--how long when you start turning the barrel does it take to realize that you have to switch directions?). The BQ is fine, but not up to the Canon L level. People say it focuses more slowly than the canon, which I assume is true because of the mechanism, but I have not had any problems with the speed of AF. So my take at the time was that it was not quite what the Canon is, but it costs 1/3 as much, and I had plenty of other uses for the other 2/3. After several years of use (I think 3, at this point), my opinion is exactly the same as it was. BTW, you should check, but my recollection from using them both at an event a year ago is that the Canon is much heavier.
