I'm wanting to do some backyard birdin with the 400 5.6 lensand my distance is little less than 10 ft. Could someone tell me what the mfd would be if I added a 12mm ext tube?
jag757 Member 239 posts Likes: 2 Joined Nov 2005 Location: NE Oklahoma More info | Dec 31, 2010 12:32 | #1 I'm wanting to do some backyard birdin with the 400 5.6 lensand my distance is little less than 10 ft. Could someone tell me what the mfd would be if I added a 12mm ext tube? Janie
amfoto1 Cream of the Crop 10,331 posts Likes: 146 Joined Aug 2007 Location: San Jose, California More info | Dec 31, 2010 13:20 | #2 Very little diffence with only 12mm on that long a lens. Alan Myers
MikeK Goldmember 1,637 posts Joined Apr 2001 Location: San Francisco area More info | Dec 31, 2010 13:33 | #3 for the 400 f5.6 L the MFD is about 11 ft (11.5 by the spec). Adding a 12mm tube, the MFD does not change too much, decreasing to perhaps 7 ft. The infinity focus with the extension tube is then about 50-60 ft. Canon 6D, 1DmkII, IR modified 5DII with lots of Canon L, TSE and Zeiss ZE lenses
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Dec 31, 2010 13:48 | #4 You might try this... http://eosdoc.com/jlcalc/ You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Thanks so much for your help. I will probably get the kenko set Janie
windpig Chopped liver More info | Dec 31, 2010 15:29 | #6 Wilt Would you like to buy a vowel?
windpig Chopped liver More info | Dec 31, 2010 15:31 | #7 jag757 wrote in post #11547826 I'm wanting to do some backyard birdin with the 400 5.6 lensand my distance is little less than 10 ft. Could someone tell me what the mfd would be if I added a 12mm ext tube? I tried a 12 and 24mm on my 400 f5.6 a couple years ago. I found it to be to constraining for what I got out of it. Would you like to buy a vowel?
Windpig, constraining in what way? Janie
windpig Chopped liver More info | Jan 01, 2011 15:11 | #9 jag757 wrote in post #11548948 Windpig, constraining in what way? I didn't feel comfortable locked into the minimum and maximum focus distances that the tubes provided. It was a couple of years ago, so maybe I should give it another shot. I've been thinking of getting the 300 F4 IS to provide a bit better MFD and IS. I do a bit of close up flower shots. Would you like to buy a vowel?
I've had a hard time choosing between the 300 f4 and the 400 5.6. I don't plan on using the ext tubes all the time, just when shooting at the feeders, and then, maximum focus distance will not be an issue. I am too close without the tube, though. Janie
windpig Chopped liver More info | Jan 01, 2011 19:34 | #11 jag757 wrote in post #11554085 I've had a hard time choosing between the 300 f4 and the 400 5.6. I don't plan on using the ext tubes all the time, just when shooting at the feeders, and then, maximum focus distance will not be an issue. I am too close without the tube, though. Would also like to try with a 1.4 TC. I know I'll loose AF with the 400 and wouldn't with the 300, but I think I would rather have the extra reach. Any thoughts? Some of the best birds shots I've gotten have been with my 70-200 F4 IS, only that I use it as a walk around lens and it's when I usually see the little song birds. Best birds shots for me have been grab shots of a towhee, bewick's wren and hummingbird at 200mm. Would you like to buy a vowel?
| Latest registered member is semonsters 1089 guests, 118 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
