sunking39 wrote in post #11549376
I just bought CS5 but my computer is slow. So I want to know, if I install it now, and then buy a new computer, will I have to buy PS again?
How many times can you install PS on a different computer, and is it difficult installing several copies?
How does one go about it?
PixelMagic is correct
No, you don''t have to buy P.S. again as long as CS5 is installed only on two of your computers. If you buy two new computer and don't want to leave CS5 on the old and slow ones, you can "deactivate" the CS5 in the old computers, and install CS5 on two new computer. I went through this process last week
I had installed and deinstalled CS5 twice on one of the two new iMacs, and then installed CS5 on the newest iMac. When I tried to use CS5 on the new iMac, a window appeared on the screen indicating that I could not use the license on this computer because I already had used it on two computers, and that I had 30 days to resolve this issue.
I was not aware that when you deinstall PSE, CS5, and other Adobe applications, the deinstaller does not remove the license from the computer. So, I had to reinstall CS5 on the slightly older iMac, followed by "deactivating" it (found in the Help Menu), and then deinstalling it once more. The final step was to enter the license number on this and the newer iMac. Now I can use CS5 on both iMacs if I want to.
