Thread started 01 Jan 2011 (Saturday) 00:47
Muslin backdrop too wide, need advice!
Foggy
Jan 01, 2011 00:47 |  #1
The current setup I have can only take 8.5' wide backdrops. For seamless paper I don't have a problem because I can cut the paper but any suggestions on cloth or muslin backdrops that are too wide? I am looking at some muslins but they only come in 10' and I need to chop it down to 8.5'... any ideas?
Gear/Feedback
suecassidy
Jan 01, 2011 09:43 |  #2
Why do you need to cut it? If you don't want to drape it with folds in it, just pull it tight and clamp the edges to the backdrop stand pole. unless I'm missing the obvious here???
Sue Cassidy
GEAR: Canon 1ds, Canon 1d Mark iii, Sony RX 100, Canon 50mmL 1.2, Canon 70-200L 2.8 IS, Canon 100-400L IS, Canon 14mm L, 2.8, . Lighting: Elinchrom Rangers, D-lite 400s, Canon 580/550 flashes. 74 ' Octabank, 27' Rotalux. Editing: Aperture 3
SkipD
Joined Dec 2002
Jan 01, 2011 09:56 |  #3
Foggy wrote in post #11550830 (external link)
suecassidy wrote in post #11552016 (external link)
Don't push the horizontal support pole through the looped end. Merely drape the muslin over the pole with the sides of the muslin folded in. That way you don't have the extra material in the way. Use spring clamps to fasten the muslin to the pole every couple of feet along the pole.
Clipping the sides of the muslin to the vertical support poles also makes a lot of sense. I do that quite often. I use spring clamps which are often sold as woodworking clamps.
Skip Douglas
Foggy
Jan 01, 2011 13:05 as a reply to  @ SkipD's post |  #4
Ah yes thank you both! I always looped it through the horizontal bar (that's why I could never fold it shorter). Never thought of putting it over the bar (which now I can fold it to any shorter length) then securing it against the vertical bars. The spring clamps you're talking about at hardware stores - are those also known as A clamps?
Gear/Feedback
SkipD
Joined Dec 2002
Jan 01, 2011 19:43 |  #5
Foggy wrote in post #11552985 (external link)
The type of spring clamps I use are in the center of this web page from Bessey (external link).
Skip Douglas
1,776 views & 0 likes for this thread, 3 members have posted to it.
1747 guests, 168 members online
