Anyone here have a step by step instructions on how to take time lapse vid on a 5D?
imports Member 134 posts Joined Dec 2010 Location: Vacouver More info | Jan 01, 2011 14:08 | #1 Anyone here have a step by step instructions on how to take time lapse vid on a 5D? 5D MarkIIGripped
LordBrian Goldmember ![]() 1,128 posts Joined Jan 2009 Location: Surrey, UK More info | Jan 01, 2011 14:16 | #2 imports wrote in post #11553328 ![]() Anyone here have a step by step instructions on how to take time lapse vid on a 5D? Do mine with a 7D but should be the same Canon 7D | EF 100-400mm L my favourite bits of kit
themadman Cream of the Crop ![]() 18,871 posts Likes: 14 Joined Nov 2009 Location: Northern California More info | Jan 01, 2011 14:16 | #3 Pretty much you need a triggering device and then take some longish exposures ... it really depends how long you want the video to be in the end. Will | WilliamLiuPhotography.com
ArcticShooter Goldmember ![]() 1,828 posts Likes: 1 Joined Dec 2006 Location: Arctic Norway (Tromsø) More info | Jan 01, 2011 14:25 | #4 You should set the white balance to a fixed setting otherwise it will keep changing Helge
Jan 01, 2011 15:29 | #5 Thank you for all the input guys, im going to try this tomorrow. 5D MarkIIGripped
LordBrian Goldmember ![]() 1,128 posts Joined Jan 2009 Location: Surrey, UK More info | Jan 01, 2011 15:38 | #6 themadman wrote in post #11553376 ![]() A trigger like this will work fine, you DON'T need a computer or any silly software to take the shots. You don't but if you have them there is no harm in using them, after all they are free Canon 7D | EF 100-400mm L my favourite bits of kit
themadman Cream of the Crop ![]() 18,871 posts Likes: 14 Joined Nov 2009 Location: Northern California More info | Jan 01, 2011 15:39 | #7 LordBrian wrote in post #11553777 ![]() You don't but if you have them there is no harm in using them, after all they are free ![]() That way you can see if you like it before buying a trigger. Also if you want a new reason to drool try this http://vimeo.com/13858358 ![]() LordBrian wrote in post #11553374 ![]() Do mine with a 7D but should be the same 1. Get a laptop, I use a cheap Dell Mini 9 with OSX 2. Plug in via USB 3. Fire up EOS utilities 4. In the utils there is a setting which allows you to do x number of shots every x mins 5. Play with timing..... I do sky with one every 15 secs but you need to play with timing 6. Shoot jpeg is the easiest as you don't need to convert later. 7. I have Quicktime Pro so when all done just open that and you can select a folder and duration (fps) and it makes the movie for you. 8. I then compress with Final Cut Studio's Compressor I am an OSX man not sure about making the movie on Windows. If the OP does not have a laptop, then he needs a laptop, which costs loads more than a trigger Will | WilliamLiuPhotography.com
LordBrian Goldmember ![]() 1,128 posts Joined Jan 2009 Location: Surrey, UK More info | Jan 01, 2011 15:41 | #8 themadman wrote in post #11553780 ![]() If the OP does not have a laptop, then he needs a laptop, which costs loads more than a trigger ![]() That made me laugh Canon 7D | EF 100-400mm L my favourite bits of kit
lilricky Member 42 posts Joined Jun 2004 More info | Jan 16, 2011 22:27 | #9 LordBrian wrote in post #11553777 ![]() Also if you want a new reason to drool try this http://vimeo.com/13858358 ![]() That is sweet.
highstakes Member ![]() 182 posts Joined Jun 2009 Location: Northern Illinois More info | Jan 17, 2011 00:07 | #10 LordBrian wrote in post #11553374 ![]() Do mine with a 7D but should be the same 1. Get a laptop, I use a cheap Dell Mini 9 with OSX 2. Plug in via USB 3. Fire up EOS utilities 4. In the utils there is a setting which allows you to do x number of shots every x mins 5. Play with timing..... I do sky with one every 15 secs but you need to play with timing 6. Shoot jpeg is the easiest as you don't need to convert later. 7. I have Quicktime Pro so when all done just open that and you can select a folder and duration (fps) and it makes the movie for you. 8. I then compress with Final Cut Studio's Compressor I am an OSX man not sure about making the movie on Windows. Any free-alternative to QT Pro? Canon 5D II - Canon 16 - 35 f2.8L II - Canon 70 - 200 f2.8L IS II - 430EX II
LordBrian Goldmember ![]() 1,128 posts Joined Jan 2009 Location: Surrey, UK More info | Jan 17, 2011 13:37 | #11 highstakes wrote in post #11656287 ![]() Any free-alternative to QT Pro? I didn't look to far as I had QT Pro, but sure there must be something out there, it was just QT was so easy. Canon 7D | EF 100-400mm L my favourite bits of kit
rdchamb Member ![]() 134 posts Likes: 1 Joined Aug 2007 Location: Long Beach, CA More info | Jan 17, 2011 23:05 | #12 highstakes wrote in post #11656287 ![]() Any free-alternative to QT Pro? For pc ... Rich
y 1600 |
Log in Not a member yet?
Registered members may log in to forums and access all the features: full search, image upload, follow forums, own gear list and ratings, likes, more forums, private messaging, thread follow, notifications, own gallery, all settings, view hosted photos, own reviews, see more and do more... and all is free. Don't be a stranger - register now and start posting! |
Latest registered member was a spammer, and banned as such! 824 guests, 312 members online Simultaneous users record so far is 15144, that happened on Nov 22, 2018 |
