Thread started 01 Jan 2011 (Saturday) 21:49
First portrait(?)
Intolight23
Jan 01, 2011 21:49 |  #1
So normally I don't take photos of people but I'm slowly starting to. I took this one on NYE but I have a couple of questions.
First, notice the blue and white reflections on middle/bottom of the photo. There's tons of these reflections on shots I took last night and I'm not sure why that is. I'm wondering if it's because of the ND filter. Should I replace that filter and get a new one or is there a way of fixing that problem?
Also is the background bokeh too bright?
IMAGE: http://i3.photobucket.com/albums/y52/sk8gitar23/IMG_0779.jpg
Also in this second picture I didn't get the full shot of her arms and it ended up being cut in the shot. Is it distracting or does it not matter? The more I look at it, the more I wished the hands would've been in the photo as well.
IMAGE: http://i3.photobucket.com/albums/y52/sk8gitar23/IMG_0761.jpg
My Flickr (external link) || My Project 365 (external link)
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Jan 01, 2011 21:52 |  #2
Those spots are flare from light bouncing around between the lens and the filter. You could probably do without the filter for that shot. Both of these are a bit soft, the second one more than a bit. I'm not sure if its a focus or motion issue.
LettieVonDread
Joined Nov 2010
Jan 01, 2011 21:59 |  #3
In both of these, I would have made another effort to capture the shot.
Intolight23
Jan 01, 2011 22:01 |  #4
I cranked up the luminence noise reduction and softened both of them up. I know the 2nd one was definitely not in focus but I tried to save it.
It's impossible for me to do night shots without flash and tripod. These were both at f/1.4 1/15 shutter speed for the first photo and f1.4 1/30 for the 2nd. I'm thinking it's a motion issue but it can be a focus issue since it was at f/1.4.
Intolight23
Jan 01, 2011 22:07 |  #5
LettieVonDread wrote in post #11555628 (external link)
I know, right? But from the view finder it looked in focus so I just kept it as is. My BIGGEST problem is getting shots in focus. About 80% of the shots I took last night was out of focus. Probably cause my aperture and shutter speed weren't really set to hand held friendliness but ugh... It's been frustrating the hell out of me without having an external flash.
LettieVonDread
Joined Nov 2010
Jan 01, 2011 22:10 |  #6
Are you shooting in manual or autofocus? Earlier I saw someone make the suggestion to turn the built in flash on to autofocus then turn it off when you go to snap the photo. I haven't used this method, but maybe it could benefit you.
You could also try having your model pose and use a tripod.
jetboy
Jan 01, 2011 22:59 |  #7
What camera are you using? My XSi has a flash right on top and using it would have produced a better product that OOF, flat, and noisy images.
Once in a while, in challenging conditions, you can get a good image. There is a reason some ppl have a bag full of equipment. The rest of the time, you need that gear to produce the best image. Stick to situations your equipment can work in for now until you get more toys to expand your pleasure.
That said, I actually like the first image. I don't find OOF images as keepers usually, but, this one is close enough. Just a touch too yellow on my screen though (not much, just a hint). Keep practicing.
Canon XSi | Σ 30mm f/1.4 | EF 50mm f/1.8 II | EF-S 18-55 f/3.5-5.6 IS | EF-S 55-250mm f/4-5.6 IS
gonzogolf
Gallery: 561 photos
Jan 01, 2011 23:12 |  #8
You had a ND filter on and you were shooting at those speeds? I hope you meant UV filter.
Skrim17
Jan 01, 2011 23:13 |  #9
you need to increase your ISO to get a faster shutter speed.
Crissa
Intolight23
Jan 01, 2011 23:15 |  #10
I took some inside the bar which I HAD to use the built in flash cause it was so dark. It was surprisingly better than I thought it would be. I'm so paranoid about using built in flash because it seems like it produces crappy pictures.
I've got enough money saved up for a 580ex ii, so I'm planning on getting that tomorrow.
Guess I gotta keep chugging along. Maybe it's me but I actually thought the first one was in focus even in post. I think I should get my eyes checked lol.
Intolight23
Jan 01, 2011 23:16 |  #11
gonzogolf wrote in post #11555980 (external link)
yeah UV lol.
1,648 views & 0 likes for this thread, 5 members have posted to it.
First portrait(?)
2810 guests, 173 members online
