Thread started 02 Jan 2011 (Sunday) 05:55
PShop Wizards.. BEST way to save a Jpeg??
The ­ Shaheen
Jan 02, 2011 05:55 |  #1
I am not sure if this is the right place to post this or if it has been asked before..
To all Photoshop wizards.. What is the best and high-quality way to save a Jpeg, probably to upload to web, but also to look great when opened??
I have seen some planet shots by NASA before.. The jpeg files on the web were tiny, but when opened, the quality was fantastic and the size grew to massive proportion, so they knew what they were doing..
For the above question, i mean:
- Smallest size, but best quality..
- Best dpi
- Best mode, bits, colours
- Least noisy
- Baseline optimized etc..
- Anything else that i haven't thought of..
Go for it..Happy 2011 to all..
"Tt's not the Devil in the details, it's God!"
https://photography-on-the.net …p=11498080&post​count=2620
tzalman
Fatal attraction.
Jan 02, 2011 06:43 |  #2
In general the smaller the size the lower the quality, however the relationship is not linear. In the area of the high quality numbers (9-12) the increase in quality as the number increases is marginal but the increase in file size is substantial. Probably 9 is the best compromise between the two parameters.
Best dpi
Absolutely irrelevant to web display, has no effect on image.
All jpgs are 8 bits; you don't get to choose. sRGB color space until the day comes when everybody has wide gamut monitors or all browsers are color managed.
Least noisy
Strictly speaking camera generated noise is independent of image format; however, excessive jpg compression can create noise-like artifacts. Any level above 7 should be safe from this.
Elie / אלי
The ­ Shaheen
Jan 02, 2011 07:16 |  #3
This is not an answer to the post above, thanks for answering though, just trying to explain myself a bit better..
I have been using PShop for ages and i know about saving in 1-12 and maximum quality.etc..
It's more, as in the NASA pictures, the relationship between the 72 dpi and the proportion to the saved size and how amazing the quality and size they were when opened..
Just thought, they were doing something i didn't know about..
tonylong
...winded
Gallery: 60 photos
Jan 02, 2011 09:22 |  #4
I'm not clear on something -- are you talking about in image that displays as small and then when you click on it "opens" to a larger, higher quality image? Various Web hosts allow you to upload a large high-quality file and then compress the images to a "normal" viewing size that you can choose to view at full size (or other sizes).
Tony
Sorarse
Jan 02, 2011 09:31 |  #5
The 72dpi has absolutely no bearing on the proportion of the saved size. Below are two versions of the same image. Both images measure 750x500 pixels. The top one was saved with an embedded resolution of 72dpi whilst the lower one was saved at 300dpi.
If you can see a difference between the two images, you've got better eyes than me.
IMAGE: http://www.88qv.com/net/070.jpg
IMAGE: http://www.88qv.com/net/070a.jpg
With regard to the NASA images, they are using a small low res image to link to a much bigger image, which obviously looks better as it is a lot bigger. But they are using two different versions of the same image to do this.
At the beginning of time there was absolutely nothing. And then it exploded! Terry Pratchett
http://www.scarecrowim​ages.com (external link)
Canon PowerShot G2
The ­ Shaheen
Jan 02, 2011 09:32 |  #6
No..
I am not talking about a Web Image 'linked' to a Higher Res image from a server..
These NASA images, i think some Telescope sites do it as well.. I just pulled the jpeg to my desktop and it was a tiny file like 250k or something..
Checked it in PShop, it was saved as 72 dpi, but then when i looked at the dimensions above in cm's, they seemed really large.. When opened, it was a beautiful, crisp image, almost like a Tiff, no noise,nothing..
It looked like, they got some sort of 'Proportion' thing right between 72dpi and Dimensions... Meaning, really small file to download but amazing Quality when opened..
I hope i am not getting myself in knots here.. I was just wondering if there's a nice trick like thisto save Jpeg's as really good quality but small as well..
Sorarse
Jan 02, 2011 09:39 |  #7
Without looking at their site, I can't imagine or work out what they are doing from your description. Sorry that's not much help to you.
Canon PowerShot G2
The ­ Shaheen
Jan 02, 2011 09:50 |  #8
Thanks for trying to help... Strangely your second image opened up as '3000' dpi in my PShop... Quite impressed with the small size though..
These are the sort of images i mean, don't worry, they are there to DLoad, so nothing illegal...
http://www.nasa.gov …-2008-28-a-print_full.jpg (external link)
I think they are doing something to the 'Pixel' sizes, rather than 'Dimension' or 'Dpi'....
tonylong
...winded
Gallery: 60 photos
Jan 02, 2011 10:16 |  #9
That link opens to a "small view" image -- 561x449 pixels. When you click on the image it opens the "full size" image of 3000x2400 pixels. And, if you look at the properties of either, they both show the same file, the one for the larger image. So, that's what you get -- the smaller is a link to the full-size.
Tony
ChasP505
"brain damaged old guy"
Jan 02, 2011 11:23 as a reply to  @ tonylong's post |  #10
Just a guess, but I would imagine that NASA took those photos with something slightly better than say, a 300D with the kit lens. Could that have something to do with the quality?
Chas P
Ugly ­ Joe
Jan 02, 2011 11:38 |  #11
ChasP505 wrote in post #11558015 (external link)
I will have you know, that this statement has put an image in my head of the large, majestic Hubble Space Telescope drifting in space, with a Rebel duct-taped to the end of it...with the flash extended.
"Hell is an eternity of getting up at 4am to nothing but decaf coffee..."
A good friend will help you move.
A true friend will help you move a body.
An old friend more than likely will pass on either because of a bad back.
J.Napier
Jan 02, 2011 11:46 |  #12
This may have no bearing on the topic, but these images were more than likely taken with a high res CCD imaging system. Very long exposers and more than likely multiple images stacked on a camera that you and I would never ever be able to afford let alone launch into orbit where you are not dealing with atmospheric condtions that we are subjected to here on earth.
That said, you can obtain some nice images with a properly balanced and polor aligned auto tracking scope and a Sbig CCD camera. http://sbig.com/ (external link) not a cheap hobby though. You can do pigy back with a CMOS sensor but you will not get the same results.
I have a pier mounted 8"Meade LX 200 in a roll off roof observatory in my back yard, howevr I sold my older ST-7 CCD camera awhile back.
OP are you interested in astro photography or just the ability to link these types of images? If its astrophotography a good site to visit is http://www.astromart.c​om/ (external link)
Lots of good info on the fourms and used equipment can be had here.
Hope this helps
Jeff
www.jni-ss.com / (external link)Blog (external link)
Sportshooterpage (external link) / Maxpreps (external link)
Facebook  (external link)/
The ­ Shaheen
Jan 02, 2011 12:03 |  #13
tonylong wrote in post #11557684 (external link)
My apologies, Tony..
It didn't seem to me, that there was a link there.. Well done..
Sorarse
Jan 02, 2011 12:43 |  #14
The Shaheen wrote in post #11557528 (external link)
You're right, it is 3000, but that proves my point. The embedded DPI figure in an image has no bearing on how it is displayed on the web. What matters when it comes to web display is the size of the image measured in pixels.
Canon PowerShot G2
CircuitR
Jan 02, 2011 15:45 |  #15
Ugly Joe wrote in post #11558083 (external link)
LOL bw!
5D mkII | 35L | 16-35mm F4 L IS | 50mm f1.4 USM | 135L |
EOS-M | 22mm f2 STM |
Instagram (external link)
2,605 views & 0 likes for this thread, 10 members have posted to it.
2891 guests, 135 members online
