Thread started 02 Jan 2011 (Sunday) 15:06
Monitor profile
Lonestarlady61
Location: Montana for over 13 years but I'm originally from Houston, Texas.
Jan 02, 2011 15:06 |  #1
I read about making sure that your monitor is calibrated correctly. How do you go about doing this and what is the best color profile to use for photos? :confused:
Canon 60D since Dec. 2011, Canon 28-135mm lens, Canon 70-300mm USM lens and Nifty Fifty 50mm 1.8 lens. Just got in a new lens: Tamron 18-270mm ; )
Titus213
Jan 02, 2011 19:07 |  #2
A calibrated monitor insure you see what is really going on in your photos. Here's a link to help (it's not a simple issue as you will see). - https://photography-on-the.net/forum/showthre​ad.php?t=296149
The best method of calibrating the monitor is with a hardware device that actually measures the colors on the screen and sets the proper profile for the monitor. I use a bottom of the line Spyder2Express.
The monitor profile is a hardware profile and is not used for your pictures. For your pictures I would highly recommend sRGB. It's what the web and most photo print outfits want.
Dave
Perspiring photographer.
Lonestarlady61
Jan 03, 2011 02:35 |  #3
Titus213 wrote in post #11560259 (external link)
Thanks for all the great info. I found a program to help calibrate my monitor. It's called Quick Gamma. I think it helped some. I will make sure that my color profile is sRGB.
ChasP505
"brain damaged old guy"
Jan 03, 2011 11:46 |  #4
Lonestarlady61 wrote in post #11562479 (external link)
Your monitor is NOT calibrated unless you use proper calibration hardware and software. On a budget, the Spyder3 Express sells for about $80 USD, but the X-Rite EyeOne Display2 ($175) would be my first choice.
And don't confuse the custom monitor profile created by calibration devices with the working RGB color space you would set in an application like Photoshop. In other words, DO NOT set sRGB as your monitor profile.
Chas P
René ­ Damkot
Jan 04, 2011 05:17 |  #5
ChasP505 wrote in post #11564444 (external link)
And also: Don't set your monitor profile as a working space. ;)
PSCSx color settings: http://www.getcolorman​aged.com …nagement/pscolo​rsettings/ (external link)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
1,152 views & 0 likes for this thread, 4 members have posted to it.
Monitor profile
2891 guests, 135 members online
