Thread started 03 Jan 2011 (Monday) 14:53
Are soft copies of Canon 50mm 1.4 common ?
m.shalaby
Jan 03, 2011 14:53 |  #1
I just got a Canon 50mm 1.4 and wasn't happy with its performance, even stopped down to 2.0 - very soft images (check out the model shoot I did on my flickr to see what I mean).
Is this acceptable & common? Is this just how this lens is? Or did I get a bad copy?
I sent that one back to B&H, and now have a new one (same thing, Canon 50mm 1.4) out for delivery today. Should I expect the same softness, or was this just an odd ball case?
If this next one is still soft, I guess I'm going to have to play the "Sigma Lens Lotto"...
ni$mo350
Jan 03, 2011 14:55 |  #2
Mine was extremely sharp. Maybe it needs to be sent in for calibration.
-Chris-Website (external link)|| (external link)Facebook (external link)|| My Flickr (external link)|| Follow me!!! 500px (external link) || (external link) 5D mkii || 35L || 70-200 f/2.8L IS MKII || My bank account hates you all :cry:
anscochrome
Jan 03, 2011 15:05 |  #3
That particular lens is weak at F 1.4 and F 2.0 (but so are a large number of similar 50mm lenses), but @F 2.8 and beyond, it is good or better than anything out there (imo). If you want a 50mm F 1.4 lens to primarily use @ F1.4 or 2.0, the Sigma 50mm F1.4 would be a better bet. If F 1.4 or 2.0 is for very occasional use, and you are at F 2.8 and smaller, the Canon is just fine. Mind you, we are talking optical quality here, not build/AF reliability and or physical property issues.
http://anscochrome.zen​folio.com (external link)
jwcdds
Gallery: 1851 photos
Joined Aug 2004
Jan 03, 2011 15:08 |  #4
Maybe it could have used some micro focus adjust.
Julian
ni$mo350
Jan 03, 2011 15:12 |  #5
If you need proof that the Canon 50 is sharp even wide open then just check out what Jordan does in the lens sample thread. I thought mine was incredibly sharp at 1.4. I didn't need to MA or anything. Here's a shot of my brother's old Z shot at f/1.8
http://www.flickr.com …in/set-72157624472937172/ (external link)
macroimage
Jan 03, 2011 15:26 |  #6
After I got my EF 50/1.4 back from having the AF motor replaced and calibrated, it seems to be as about as sharp as the 50/1.8 II now which is much improved over how it originally was. It is pretty decent and accurate now. Focus seems more accurate on my XTi and 5D. With the Rebel and XT, it is more inconsistent and the 1.8 generally does better with those cameras for me.
These lenses are low contrast at f/1.4 and mostly only sharp near the center which leads to a feeling of softness. Also the depth of field is very thin so not much will be in focus anyway even at a distance. The focus plane may not be perfectly flat either so test charts may not be good subjects either.
Photo Gear
m.shalaby
Jan 03, 2011 15:37 as a reply to  @ macroimage's post |  #7
thanks guys.
it seems i just got a bad copy... hopefully the new one I exchanged for is better.
LowriderS10
Jan 03, 2011 15:40 |  #8
Also beware of front/back focus...my second 1.4 was ridiculous for front focusing...
-=Facebook=- (external link)
-=Flickr=- (external link)
-=Gear=-
hieu1004
Jan 03, 2011 15:47 |  #9
Post a picture next time - a good copy of the 1.4 should be rather sharp (or not soft). The copy I had required some MA as it was front focusing a little.
-Hieu
Gear | Blog (external link) | flickr (external link)
HyperYagami
Jan 03, 2011 16:06 |  #10
hieu1004 wrote in post #11565880 (external link)
check his flickr.
yes i think it's little softer than it should but really not by that much.
5D3 and a few lens
es.
workerdrone
Jan 03, 2011 16:12 |  #11
I just recently found some time to do some MA on lenses, the 70-200 and the 85 1.8 were very quick and easy to do, the 50 1.4 kept giving different results so I'm suspecting that it may have AF issues - how much does Canon charge to service the AF motor out of warranty?
I know squat about PP. Old: Canon 10-22, 18-55, 24L, 50 1.4, 50L, 85 1.8, 24-105L, 70-200 2.8L nonIS, Sigma 30 1.4, Tamron 18-200 lenses. t2i, 7D, Xsi bodies. New: D700, 14-24, 50G, 105 VR Macro, 70-300 VR, SB700
hieu1004
Jan 03, 2011 16:16 |  #12
^Ah, I missed that. Hm - yeah it doesn't seem too bad at 1.4 - a little soft - definitely try another copy.
-Hieu
muskyhunter
Joined Nov 2010
Jan 03, 2011 16:32 |  #13
try looking at a Sigma 50 or Simga 30.... very sharp @ 1.4
liupublic
Jan 03, 2011 16:49 |  #14
OP has a 60D body. Compare picture from AF vs MF in live view on a tripod. Unfortunately 60D does not have MA. So it's either a calibration or return for another lens.
Canon 50 f/1.4 is not quite sharp as at f/1.4 vs f/2 but the image should still be pretty useful. Just make sure it's not underexposed. Really need a sample picture.
Still learning
Nikon D750, Sigma 24-105OS, 105mm 2.8g micro VR, Tamron 70-300VC
yogestee
Jan 03, 2011 18:40 as a reply to  @ liupublic's post |  #15
Is the "softness" due to focusing errors or is your lens optically soft??
Jurgen
2,657 views & 0 likes for this thread, 14 members have posted to it.
POWERED BY AMASS forum software 2.55forum software
version 2.55 /
Latest registered member is Aidas.G
1414 guests, 211 members online
