Thread started 03 Jan 2011 (Monday) 18:38
XTi to 40D/50D
Bleufire
Jan 03, 2011 18:38 |  #1
I have been looking for awhile now to upgrading to a 40D in hopes of having some lower noise from taking shots at higher ISO. I am also interested in the ergo's of the XXD and higher lines. Not really a fan of the Rebel line unless it has a grip, then I am ok. Although with the drop in prices of the 50D lately I have decided to keep that in mind too.
I will be taking more shots of our first born in a couple of months but also plan on taking more shots at our local Gym for MMA/Jiu Jitsu.
Would I be more likely to notice the difference between XTi to 40D or to a 50D? I have the Sigma 30/1.4 and love it but feel that some shots could still use a cleaner higher ISO. Also in the plan is a 85/1.8.
I did my searching for 40D vs 50D threads but can't seem to get a complete answer to my specific question.
5D*Sigma 50/1.4*EF 17-40/4
New to Photography? ----> ENJOY! Canon DSLR! (external link)
Tim ­ S
Jan 03, 2011 18:43 |  #2
I went from the XTi to the 50D last year. There is no comparison to the feel of the 50D. It seems to be very well built for the price. Noise at ISO 3200 is comparable to what I got at ISO 1600 on the XTi. The controls are better laid out and the QCD on the back is very handy. That being said, I think for the same money, you could get a T2i which may be just a bit less noisy(so say users on this forum). You will like the 50D but you might want to check out the 7D. About a third more money but the AF system may make that worth it for sports.
PS- I have the 85 f/1.8-you will like that also!
Tim
Equipment
gcogger
Joined Mar 2003
Jan 04, 2011 14:38 |  #3
The difference in high-ISO noise between all these cameras is minimal IMHO. That's assuming you're shooting RAW, as the cameras apply different levels of noise reduction in JPEG shooting. I went from an XTi to a 40D and the 40D is maybe 1/3 stop better, if that. The 50D is no better than the 40D (although its JPEGs, and even images processed in DPP, have more noise reduction applied, giving the impression of lower noise).
Graeme
My galleries (external link)
robertwsimpson
Joined Jun 2010
Jan 04, 2011 14:44 |  #4
Here are some higher ISO shots from the 50d.
800:
IMAGE: http://farm6.static.flickr.com/5123/5320711335_75b51eb13a_b.jpg
IMAGE LINK: http://www.flickr.com …/40483547@N07/5​320711335/  (external link)
European Starling (external link) by robertwsimpson (external link), on Flickr
1600:
IMAGE: http://farm6.static.flickr.com/5206/5309107555_906a7d10fb_b.jpg
IMAGE LINK: http://www.flickr.com …/40483547@N07/5​309107555/  (external link)
Jet Taxi (external link) by robertwsimpson (external link), on Flickr
I think the noise is less evident on the 50d, but I've also gotten a LOT better at taking a good photo since I upgraded. I also came from an XTi. In my opinion, the best thing you can do is learn to expose to the right, fill the frame with your shot so you're not cropping later, and learn how to post process your shots. I think that a better lens will reduce noise more than a better camera. Not only the wider aperture, but also the sharpness of the lens make the noise less noticeable. I've been choosing to stop down and shoot at a higher ISO lately than shoot wide open at a lower ISO. Maybe it's just me. In my opinion, you shouldn't buy the 50d for the noise performance. You should buy it for the screen (which is a billion times better), the size and weight, the controls, the sound (yes it sounds better than a rebel), and the build quality.
robertwsimpson
Joined Jun 2010
Jan 04, 2011 14:46 |  #5
then again, I did this with the XTi at ISO1600 and 55-250mm
IMAGE: http://farm3.static.flickr.com/2718/4222428206_7dd06d786a_b.jpg
IMAGE LINK: http://www.flickr.com …/40483547@N07/4​222428206/  (external link)
Hello Squirrel! (external link) by robertwsimpson (external link), on Flickr
momenthunter
Jan 04, 2011 14:49 |  #6
In term of image quality, it's hard to tell the difference between 40D and 50D by using the same lens. What you get with a little bit more money (about $100) for 50D - back LCD with higher resolution, micro adjustment for lens back/front focus.
robertwsimpson
Joined Jun 2010
Jan 04, 2011 14:50 |  #7
The LCD alone is worth it.
mark2009
Gallery: 12 photos
Jan 04, 2011 17:21 |  #8
Bleufire wrote in post #11566951 (external link)
I see you said you are not a fan of rebels, but you could get a NEW T2i with video, which I would think you would want with a child on the way,,,,,for what you would pay for a used 50D....the 50D, you get banging FPS, but I don't think you need that.
BTW,,,where do you see a drop in 50D prices, I wish I did...I see clean used ones going for $750-800....
Jethro790
Jan 04, 2011 19:57 |  #9
robertwsimpson wrote in post #11572713 (external link)
Yeah, the shoulder LCD. It's the #1 reason I can't go back to a Rebel. Gotta have that shoulder LCD.
If you must know...
Bleufire
Jan 05, 2011 02:02 as a reply to  @ Jethro790's post |  #10
Tim S wrote in post #11566999 (external link)
I am browsing through the FS forum... My prime addiction is starting to flare up!
gcogger wrote in post #11572605 (external link)
I searched alot of forums and have discovered that the 40D/50D will not give me what I am looking for because of the exact reason you described above.
mark2009 wrote in post #11573699 (external link)
I don't *think* i need video. but then again, i didn't think i needed a prime after my 17-55 lens. I also don't need high FPS cause i don't tend to take shots like that. I considered a 5Dc but am not sure if I want to mess with selling the 17-55.
I have seen a few on the forums for $660-$700. From when i started looking at them, roughly back in Aug, I noticed that the priced drooped into the $600 mark a few times and ALMOST picked one up but i over research things and couldn't justify the purchase. I think what I learned since my first post is I need to learn to expose my shots better.
thanks all who replied!
gblader
Jan 06, 2011 21:48 |  #11
Wait... Does a better lens produce less noise? Or just the aperature of the lens?
7D 15-85 100f2
onick
Jan 07, 2011 00:09 |  #12
wide aperture = more light = low ISO = less noise .
Canon EOS 6D II | Canon EOS 550D | 18-55mm IS | 55-250mm STM | Rokinon 14mm F/2.8 | 35mm f2.0 IS | 50mm f1.8 | 135mm f2.0 L | YN-568EX II
shaftmaster
Jan 07, 2011 00:33 |  #13
I think you need an external flash if you don't have one already. A good flash will produce more consistently good indoor shots of kids than shooting at f/2 and ISO 1600. The 40D and 50D have better AF than the XTi, which will help when your kiddo starts running around.
Paul
Gear -- Flickr (external link)
Bleufire
Jan 07, 2011 01:11 |  #14
shaftmaster wrote in post #11589921 (external link)
I wanted to move up to the XXD line mainly for the AF but that is really all. I am kind bummed my ISO tops at 1600 but figured that could be remedied by using things like f/1.4-/2.0, so recently i have been researching primes.
gblader
Jan 07, 2011 04:08 |  #15
onick wrote in post #11589839 (external link)
What I meant, was let's say, you take an L lens at f4.0 vs. a kit 18-55 at f4.0, will the L(or better... don't want to get into a debate) produce less noise?
Better lens @ f4 > Crappy lens @f4 ?
7D 15-85 100f2
3,541 views & 0 likes for this thread, 13 members have posted to it.
XTi to 40D/50D
Latest registered member is finnianmarlowe
1334 guests, 172 members online
