robertwgross wrote:
Sheldon, I like what you got on the black-crowned night herons.
Here in California, I am often after those and also green herons.
My question is this. How or where is the Better Beamer most effective? These turned out good for you, but is there a minimum or maximum range that works best? I've used my 550EX on snowy egrets at a range of 65 feet before, so I know the whole lighting job is not easy.
---Bob Gross---
Bob
Getting used to the beamer took a little longer than I had anticipated but once you get it, it can produce some great results.
On the GBH in question here, he/she was about 100 feet from me and kept moving in and out of the shadows. That is why I used the beamer. When I used it on him I had dialed -1.5 on the flash output and then went anywhere from normal exposure to minus half a stop.
When it came time for the Night Heron they were much closer and I probably could have done without the beamer. They were probably about 50 feet away or less. I decided to leave it on and I dialed in-2 on the flash output and I was underexposing in some case by up to a stop or maybe even a little better.
I like the light that the beamer produces, it seems to not be as harsh as the straight flash.
I normally start with at least -1.5 on the flash unit and then do a few shots, checking the histogram. Any further exposure adustments I make on the camera. It works great for fill flash on hihg speed synch.
Here is one more of the guys that were in the trees. This one got nailed with too much flash but he was so darned funny. Had his back to us all the time and everytime he would look at the people he would bend his head down and look backwards like this.
