Thread started 06 Jan 2011 (Thursday) 13:09
Advice on prime
LittleFish
Jan 06, 2011 13:09 |  #1
Hey all,
I've enjoyed shooting with my one and only prime - the nifty fifty, during the past few months that I've owned it. Although I like the sharpness and the low-light capabilities, I find that the focal length is not really for me, since I shoot indoors mostly, (therefore I can't move back far enough to get the shots that I envision). So, I've decided within this coming month or so, that I want to replace my nifty fifty for something that's a little wider. My price range is roughly 300 USD, but I could push it slightly, if need be. I don't mind buying used. Several lenses that I've looked at are:
1. Sigma 30mm f/1.4 - I've noticed the rave reviews that this lens seems to be getting. However, i've also heard of difficulty obtaining a good solid copy of the lens.
2. Canon 28mm f/1.8 - Looked at this one briefly. There does not seem to be as many people saying anything about this lens compared to the Siggy.
3. Canon 35mm f/2 - Same as the 28mm f/1.8
Thoughts?
|Canon T1i | 50 1.8 | 18-55 IS | 17-55 IS USM | Manfrotto 190XPROB and 498RC2 |
-Syed-
shutterpat
Gallery: 33 photos
Best ofs: 11
Jan 06, 2011 13:19 |  #2
consider the 85 1.8....
gasrocks
Jan 06, 2011 13:30 |  #3
He says the 50mm is too long and you suggest an 85? Samyang/Vivitar is about to release their 35/1.4.
hieu1004
Jan 06, 2011 13:32 |  #4
^Why would he consider the 85mm when he just said the 50mm wasn't wide enough for indoor use? Are you not reading the thread?
OP: I've used/owned all those primes - I'd pick up the Sigma 30mm in a heartbeat, that is unless you have plans to go FF VERY soon.
-Hieu
Gear | Blog (external link) | flickr (external link)
Cesium
Jan 06, 2011 13:55 |  #5
All good choices. Pick one and be happy.
banpreso
Jan 06, 2011 14:24 |  #6
if you shoot indoors A LOT, i would even recommend the sigma 20mm f1.8, which is about 35mm full frame, perfect for indoor events
themadman
Jan 06, 2011 14:25 |  #7
Sigma 30 1.4 is a real nice lens. WORST case scenario, you send it is for a in warranty repair.
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
va_rider
Jan 06, 2011 14:26 |  #8
I had the 35 f/2, and it was a great lens... although a bit lacking at time for indoor low light shooting without a flash... I replaced it with the 35 f/1.4 ... this thing can almost see in the dark... I got a nice sharp copy...
If you can round up the cash... I'd go for the 35mm 1.4
Canon 5dmkIII, Sigma 15mm f/2.8FE; 35mm f/1.4; Canon EF70-200 f/2.8L IS II; --- YN560 x 7
I'm not a professional photographer, and I don't want to be.
hieu1004
Jan 06, 2011 14:33 |  #9
The said budget is 300. 35L is nowhere even near his budget. I've owned the 35L AND 24L and the sigma is going to be close to performance for around the OP's budget.
-Hieu
SexyRed
Jan 06, 2011 18:09 as a reply to  @ hieu1004's post |  #10
I was going to pull the trigger on the canon 35 f/2.0 but decided to sleep on it.
Today, I saw the sigma 30 f/1.4.
Looks like a no-brainer.
canon 35 f/2.0 $300
Sigma 30 f/1.4 $400
BH photo price.
Anybody agree or disagree. I have 1d mkii. Want a 24-70L but I think this will hold me for a good while. Main use purpose is portrait and indoor.
Austin.Manny
Jan 06, 2011 18:20 |  #11
The Siggy was designed for 1.6x crop cameras. I'm not sure if and how much it will vignette on your 1Dii.
1D Mk III | 450D Gripped | Σ 30 f/1.4 | 85 f/1.8 | 18-55 IS
Canon 430exIII | LumoPro LP180 | Yongnuo YN-460 |
RF-603
hieu1004
Jan 06, 2011 18:45 |  #12
Yeah the Sigma 30mm will vignette on your APS-H 1D, but it isn't too bad at all. Check out this old thread - it has samples of the Sigma 30mm from 1D users - looks really good. Take a look and see if that is acceptable to you.
A couple users I know of "bobbyz" and "picturecrazy" use the Sigma 30mm and own 1D bodies, so you might want to send them a message to see how they like it.
https://photography-on-the.net …hread.php?t=794​328&page=2
-Hieu
LittleFish
Jan 06, 2011 18:56 |  #13
Thanks a lot for your input guys.
I do have plans to upgrade my body, but as of right now, I can't yet decide whether to stick with crop or go FF. I figured it might be a better idea to build my lens lineup first before I even begin to think about upgrading my body. My canon T1i seems perfectly fine for me now, although I could probably use a battery grip, but that's a whole 'nother story. So, I'm assuming my next body upgrade would probably be in about 2~3 years time.
For the owners of the Siggy 30 f/1.4, how many times, if any, did you have to return it to Sigma before finally getting a good copy? How did you know that the problem was because of the lens, and not due to user error? How do you test the lens for any defects? Thanks in advance :)
-Syed-
hieu1004
Jan 06, 2011 19:06 |  #14
LittleFish wrote in post #11588113 (external link)
0 times. It worked perfectly on my T1i, but needed microadjust on my 7D (but then every prime I have needed MA on my 7D so it is body issue).
Take a lot of samples and eliminate possibilities of user error. It is not easy to shoot at f/1.4, due to the VERY thin plane of focus - so keep that in mind. Mount on a tripod, use a remote cable OR tether to a computer/notebook OR use the timer, shoot at a contrasty/perpendicula​r target and place a ruler(or similar device) along the perpendicular target to see if there is any hint of back focus or front focus. Do a search for lens focus test, there are many methods -but also, shoot at real world objects at different apertures and different distances. You'll quickly find any focus issues if it is major.
-Hieu
Austin.Manny
Jan 06, 2011 19:43 |  #15
Mine was great out of the box.
RF-603
2,492 views & 0 likes for this thread, 13 members have posted to it.
Advice on prime
Latest registered member is Aristosan
372 guests, 171 members online
