Anybody have any suggestions on creating an interactive form? I’m trying to create a type of order form that can be emailed, filled out, and then sent back to me. At the moment I’m not getting it to work the way I’d like it to.
I created a page in Publisher and converted it to a pdf. I brought it into Acrobat (5) and set the areas up with the forms tool and saved it. Everything works fine at this stage. The bad part is, once you fill it out the entries won’t save unless you use “print to pdf”. I going to guess there’s a lot of people without that option and may not download a pdf creator to be able to.
The only other way that I’ve thought might make this possible is to create a page on my website using forms and let them submit it back thru email. I’d have to try to figure that all out as I know enough html to be dangerous.
Is there something I’m missing somewhere? Thanks for any help and suggestions.
. I'm using v5 and it looks like time to upgrade. If I've read right, starting with v8 you can set pdf options that will allow a user to fill out the form and save the changes in Adobe Reader a little easier.
