I want to do the same thing to a whole series of images. Is there a way to create an Action that would apply those processes to an entire image all at once, rather than going through each image and repeating the steps one at a time?
MindlessConsumer Senior Member 308 posts Joined Oct 2010 More info | Jan 07, 2011 12:34 | #1 I want to do the same thing to a whole series of images. Is there a way to create an Action that would apply those processes to an entire image all at once, rather than going through each image and repeating the steps one at a time?
PixelPusher Goldmember 1,929 posts Gallery: 85 photos Best ofs: 1 Likes: 1205 Joined Feb 2009 Location: Surf City, USA - Left Coast More info | Jan 07, 2011 13:30 | #2 You didn't mention what application you are referring to, I assume Photoshop. If that is the case, the answer is yes. In the actions palette, you can record all the steps. Select "new action" and see the record button. Do your steps and select the stop button. After that just choose your new action on your selected image and hit play. I have a few of my own. Also the batch process works too on several at a time. Have fun. Robert
robertwsimpson Goldmember 2,471 posts Likes: 60 Joined Jun 2010 Location: West Palm Beach, FL USA More info | Jan 07, 2011 13:31 | #3 or in lightroom, just copy the develop settings and paste them to all the other images.
Jimmer411 Thank god Im green. 866 posts Likes: 2 Joined Sep 2007 Location: Pacific, WA More info | Jan 07, 2011 13:42 | #4 In LR3 you can select all images and then click the one you want to use the settings from (It will be a solid white vs the dim white of the other selections) and click sync. 5D3 | Sigma 30mm f/1.4 HSM | EF 85mm f/1.8 USM | EF 24-70 f/2.8L II | EF 70-200 f/2.8L IS II | 430EX | YN-568EX II | YN-622c | YN-622-TX |
tonylong ...winded More info | Jan 07, 2011 16:14 | #5 As has been mentioned, the software you are using makes all the difference. Photoshop CSx gives you the ability to create and "play" Actions on batches of images. Other software takes different approaches and may or may not facilitate easy batch processing. Tony
Jan 07, 2011 17:09 | #6 I am sorry. I am using CS3.
Jan 07, 2011 17:10 | #7 Allscape wrote in post #11593164 You didn't mention what application you are referring to, I assume Photoshop. If that is the case, the answer is yes. In the actions palette, you can record all the steps. Select "new action" and see the record button. Do your steps and select the stop button. After that just choose your new action on your selected image and hit play. I have a few of my own. Also the batch process works too on several at a time. Have fun. Where is the actions palette, lol?
PixelPusher Goldmember 1,929 posts Gallery: 85 photos Best ofs: 1 Likes: 1205 Joined Feb 2009 Location: Surf City, USA - Left Coast More info | Go under the "Window" menu, you will see Actions, make sure it is checked. If not it is hidden. Robert
Damo77 Goldmember 4,699 posts Likes: 115 Joined Apr 2007 Location: Brisbane, Australia More info | Jan 07, 2011 17:39 | #9 |
| Latest registered member is MWCarlsson 757 guests, 180 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
