Thread started 08 Jan 2011 (Saturday) 19:18
Glass LCD Screen Protector On A 50D
yogestee
Jan 08, 2011 19:18 |  #1
When I bought my 50D a few years ago, I stupidly put a glass screen protector on the LCD..
Now, over time, the adhesive is becoming a little milky.. Not a huge problem at this time but I'd like to remove the protector..
I was thinking of warming up the adhesive with my wife's hair drier and sliding it off in one piece..
Does anyone have ideas how I came remove the protector without breaking it and not damaging the LCD screen??
Jurgen
Saint728
Jan 08, 2011 19:26 |  #2
I would try the heating it up with a hair drier then stick a piece of duct tape over the whole thing and peal it off. If the glass does break the tape should hold it all together at least.
Take Care,
Cheers, Patrick
Canon EOS 1Ds Mark III | 17-40mm f/4.0L | 70-200mm f/2.8L USM | 100mm f/2.8L IS Macro | 300mm f/4.0L IS
Click Here To See My Gear
Click here to see my Flickr (external link)
http://www.runryder.co​m/helicopter/gallery/9​019/ (external link)
yogestee
Jan 08, 2011 20:15 |  #3
Saint728 wrote in post #11601024 (external link)
Take Care,
Cheers, Patrick
Great,, thanks Patrick:D
Jurgen
Bang ­ Bang ­ Boy
Joined Nov 2010
Jan 08, 2011 20:17 |  #4
Be careful so that you do not warm up the heating holding the cameras own protective glass, otherwise you might loosen that aswell and pull it out with the one you put there.
Lots of old stuff but hey I am a student
Photojournalist in Johannesburg.
SuperHuman21
Jan 08, 2011 20:20 |  #5
I have no idea how much it'd affect the LCD glass but you could try nail polisher, WD-40, a razor, windex and I'm sure I'm forgetting others.
D90, 105mm f/2.8, 18-105mm DX, D-Lite 2 it (3), 32" Photoflex softbox (2), Manfrotto 3021BN w/3047 head
Arthur
-Stones and Jewelry Photographer-
yogestee
Jan 08, 2011 20:29 |  #6
SuperHuman21 wrote in post #11601301 (external link)
I need to remove the glass protector first.. By the looks of it there would be no way I'd be able to get a solvent between the protector and screen..
What I have noticed though, on warm days, I can wriggle the protector around just a little.. That's why I'm thinking heating the adhesive up with a hair drier just enough to slide the protector off..
Jurgen
SuperHuman21
Jan 08, 2011 20:38 |  #7
I figured you might be able to lift it a little with a razor and if you let it sit there the solvent could eat away at it for a little until you could lift the whole thing. The heat thing sounds good but like someone pointed out already, you may pull the glass out with it.
Arthur
sandpiper
Jan 08, 2011 20:56 as a reply to  @ SuperHuman21's post |  #8
It may be worth ordering another standard fit protector from Canon, they are only a few dollars, and that way if you loosen both protectors you have a new one ready to be fitted. Should the standard protector stay stuck, then you have a spare and don't need to worry about sticking a second protector on to the original protector again. Should the original get damaged you can simply swap it for the spare.
To be honest, I have always found the original fitment protectors extremely resistant to damage and never seen a need to protect the protector, especially as replacements are cheap.
SuperHuman21
Jan 08, 2011 21:18 |  #9
I just use a plastic protector that's worked great so far. Only downside is needing to clean it from the inside from time to time.
Arthur
2,431 views & 0 likes for this thread, 5 members have posted to it.
1464 guests, 137 members online
