Thread started 09 Jan 2011 (Sunday) 11:30
vagabond alternative?
unlimited6986
Jan 09, 2011 11:30 |  #1
would this work to power up 2 AB800?
http://www.amazon.com …3&creativeASIN=​B000TKHMWK (external link)
just saw these and was just wondering.
dmward
Gallery: 29 photos
Jan 09, 2011 11:44 |  #2
I doubt it.
Monolights require a pure sine wave inverter. Most of these kinds of devices use modified sine wave converters and put the monolights at risk.
unlimited6986
Jan 09, 2011 11:49 |  #3
ahh ok i got it. Just trying to not pay the 300$ for the vagabond. maybe ill try to do the DIY one
43 ­ North
Jan 09, 2011 12:26 |  #4
OK so I understand that the lights require a pure sine wave but can someone explain the technical reason why this is? What exactly is it in the strobe that is at risk for damage by using a modified sine wave?
MIKE - Flickr (external link)
7D Gripped ~ T2i Gripped ~ Canon 28-135mm ~ Canon 50mm 1.4 USM ~ Canon 24-70mm f2.8L ~ Canon 70-200mm f4L ~ Alien Bees B1600, B800x2, B400 ~ 580EX II ~ Event Trailer
ΜΟΛΩΝ ΛΑΒΕ
www.43northphotography​.com (external link)
drdiesel1
Gallery: 86 photos
Jan 09, 2011 12:55 |  #5
unlimited6986 wrote in post #11604414 (external link)
I did a DIY that will power at least 4 strobes all day long :cool:
I used this inverter: http://www.amazon.com …ter-Control/dp/B000WGNNUQ (external link)
I used this size battery: http://www.autozone.co​m …entifier=115786​_175927_0_ (external link)
I used this Cart without the insert for 100 bucks: http://www.zuca.com/sh​owroom/ (external link)
You can use any battery and cart you like. I made mine with this set-up for extra power with sturdy portability. Otherwise known as Over Kill
Nikon D810 Nikon 50F/1.4G - Nikon 70-200F/2.8II
Canon 5DMKIII - Canon 24-105F/4L
43 ­ North
Jan 09, 2011 13:22 |  #6
DrDiesel can you post a pick of your actual setup?
ΜΟΛΩΝ ΛΑΒΕ
drdiesel1
Gallery: 86 photos
Jan 09, 2011 13:29 |  #7
43 North wrote in post #11604878 (external link)
Sure. It's not done yet, but I've been using it like this for a while :cool: I plan on putting plastic panels on it to close it in or maybe using the freebie bag that came with it.
This picture shows the unit with my charger and remote control on top. The remote comes with the inverter
Here's the charger info:http://www.batterychar​gers.com …x?ProductName=9​4026807ACP (external link)
It runs my 2 AB1600's, 1 AB800, my laptop and a 24 inch monitor for hours on end. The best part is the items are individually warrantied and if one fails, I can just replace that one item. It makes a great light stand anchor too.
I used this battery because it's the same as the one in my car. The charger is attached with velco and can be used for everything else around the house.
I wouldn't recommend anything less that a 1000 watt inverter. Lots of overhead works better for me, but I like over-kill.
110yd
Joined Jan 2005
Jan 10, 2011 00:18 as a reply to  @ 43 North's post |  #8
Using a square wave inverter can cause damage to some electrical equipment. The voltage that is generated from a square wave inverter does a poor job of approximating a sine wave, and can damage your equipment. The link below has an image of the output of a sine wave and modified sine wave inverter.
http://www.nooutage.co​m/inverter1.htm#wavefo​rms (external link)
Hope this helps,
110yd
1,945 views & 0 likes for this thread, 5 members have posted to it.
1372 guests, 188 members online
