Teeny - The Fuji HS10 gets very good reports on Forums for Macro ability. I can agree with that - it does work very well.
The US Price is around $350.00 (I've Googled it at $339.00) so fits his budget.
Standard Macro Wide-end is 10cm to 3-metres / 0.3ft to 9.8ft
Tele-end is 2m to 5-metres / 6.6ft to 16.4ft
Super Macro - 1cm to 1-metre / 0.4" to 3.3ft.
The HS10 works well on a table tripod. The twist-zoom makes adjusting distance setting precise and easy.
At ISO 100 and 200 there is almost no noise, and at ISO 400, very little.
It has RAW and RAW+JPEG for processing to better detail from 15MB+ RAW files.
The fast-continuous shooting, at 10-7-5-3fps, can be used in Macro Mode (For moving insects, quickly changing light, etc.) JPEG only, RAW, and RAW+JPEG can be used. In RAW modes fastest continuous is 5fps or 3fps.
The Manual Focus works quickly and accurately, with an On/Off magnifier if needed. (Press the AE/AF button on back of the camera. The camera then uses the AF function to approximate focus, then "rock" the focus-ring on the barrel a few mm either way to "centre" sharpest focus.)
The HS10 uses SD/SDHC cards up to 32GB. Power is 4 x AAs. Eneloop rechargeables give 400-450 stills images (no flash or video), and AA alkalines or lithiums can also be used. I get about 300 stills from alkalines, and Fuji claims 700 from lithiums, but I can't verify that.
The barrel face is threaded for 58mm filters.
When used for "no vibes" work, the 2 or 10 second Timer is quickly accessed via the Down-Arrow of the 4-way pad.
If needed, Video at 1920 x 1080, 1280 x 720, and 640 x 480, works in Macro or Super Macro Modes, as does High Speed (slow-motion playback.)
Under "Scenes Modes" there is a Preset for Text and Documents.
Any questions elsewise - post back.
Dave.
