I searched for this but didn't have any luck...
Can you xt users tell me what program (if any) you use to tell the number of shutter actuations?
I'd like mac software, but can use windows if mac s/w isn't available.
Thanks in advance.
- Erin
Jan 09, 2011 18:29 | #1 I searched for this but didn't have any luck...
Phi404 Member 111 posts Joined Dec 2010 Location: Florida More info | Jan 09, 2011 20:00 | #2 Unfortunately, from what I've read, there is no way to get the ACTUAL number for the XT without going through Canon. I've tried several exif programs as well to see as well...if you do find a way without using the CHDK firmware lmk gjl711 wrote: However, you can estimate the total number of shutter actuation if the following things are true. 1. You are the only owner and you purchased the camera new. 2. You have never reset the image count. 3. You have never plugged in another CF card with an image count higher than the one in your camera 4. You have never removed both batteries. (not sure about this one on the XT) 5. You have always have the file numbering in continuous mode If those are true, then you can use the folder number -100 * 100 plus the image count. That should get you within a few snaps. Gripped Canon 350D ; Mamiya/Sekor 1000 DTL
| Latest registered member is griggt 1402 guests, 127 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
