Thread started 09 Jan 2011 (Sunday) 20:27
All my primes have microadjusted to +13. Should I worry?
Dr.Pete
Jan 09, 2011 20:27 |  #1
So, it's a little odd, but all my primes seem to front-focus a little on my 5D2, and my 85L and 50/1.4 (now sold) both did it. After tweaking my new 35L, it seems best at--you guessed it-- +13. The only time I haven't used MA with a prime was when I rented a 50L and it was pretty much spot-on, though I didn't test it on my LensAlign.
Is there some issue with my 5D2 body, or should I just say "meh, that's why MA was invented" and leave it at that? It just seems like a very odd coincidence...
Tools of the dark side | MacBook Pro/LR3/Photoshop CS5
“Gear Is Good, Vision Is Better.” -- David duChemin
AJSJones
Gallery: 6 photos
Joined Dec 2001
Jan 09, 2011 20:31 |  #2
I think the camera can tell the difference between the ones you paid for and the ones you rent.
My picture galleries (external link)
Cokeman
Jan 09, 2011 20:40 |  #3
Sounds like your 5D2 might be the issue... maybe the one your rented would be MA'd -13 on a normal body? :)
But then again, you don't mention the zoom lenses, so I'm assuming those don't need MA, which would be odd if the body was the problem (unless they are like your rental lens that would go the other way!)
T2i, 70-200/4, 28/1.8, 85/1.8, 28-135, 18-55, 55-250, 430EXII
Dr.Pete
Jan 09, 2011 20:50 |  #4
Cokeman wrote in post #11607489 (external link)
Hehe... I was thinking the same thing. Maybe I got one of those "bad" 50L's. :D
The zooms are a non-issue across the range. both the Brick and the 70-200 IS II are fine at 0 MA.
I guess we'll see where my new 50L and my (eventual) 85 1.8 settle out...
xarqi
Jan 09, 2011 20:54 |  #5
Dr.Pete wrote in post #11607416 (external link)
...or should I just say "meh, that's why MA was invented" and leave it at that? It just seems like a very odd coincidence...
Sounds good to me.
Dr.Pete
Jan 09, 2011 20:55 |  #6
xarqi wrote in post #11607577 (external link)
Sounds good to me.
I think you're probably right. :)
hieu1004
Jan 09, 2011 21:49 |  #7
I have the same problem with my 7D. All my primes need +15, zooms are fine. Just leave it alone if it's within the range.
-Hieu
Gear | Blog (external link) | flickr (external link)
Cokeman
Jan 10, 2011 10:20 |  #8
hieu1004 wrote in post #11608005 (external link)
Pardon my ignorance, but what's "within the range" mean? I don't have a camera with MA, but it's still good to learn the terminology for whenever I upgrade.
Dr.Pete
Jan 10, 2011 10:23 |  #9
Cokeman wrote in post #11610516 (external link)
Microadjustment goes in arbitrary units from +20 to -20, so that's the range in which you can fix front/back focusing issues. Outside of that the lens/camera need(s) to be calibrated.
For instance, I just bought a Sigma 50mm that was front-focusing badly enough that even at +20 I couldn't get it into focus, so I returned it. If you can correct it with microadjustment within that +/- 20 range, though, you can essentially calibrate the lens/body yourself. I'll never own another camera without that feature.
hieu1004
Jan 10, 2011 10:26 |  #10
With an MA capable body. You have a range of -20 to +20. If its within those ranges, I don't worry about it.
-Hieu
m.shalaby
Jan 10, 2011 12:13 as a reply to  @ hieu1004's post |  #11
That would bug the heck out of me. If all your lenses are the same, then it seems your body is in need of calibration.
Both the body and or the lens can be 'off'. In this case, it seems your body is.
BioSci
Gallery: 94 photos
Joined Nov 2010
Jan 10, 2011 12:46 as a reply to  @ m.shalaby's post |  #12
I've calibrated two lenses with my 7D: the kit 28-135 and the Canon 75-300 USM 4.0–5.6. Both required a MA setting of -10. So long as I can take sharp photos with each, I don't really care if the camera is a little out of adjustment or both lenses are. Should I be concerned like the OP?
EOS R | EOS 7D
RF 800 f/11 | 24-70 f/2.8L II | 70-200 f/2.8L II | 100-400 f/4.5-5.6L | 17-55 f/2.8 | 11-16 f/2.8
m.shalaby
Jan 10, 2011 13:06 |  #13
BioSci wrote in post #11611321 (external link)
You just answered your own question.
Me. I want things "right". I would send it to Canon for calibration.
charld
Jan 12, 2011 09:59 |  #14
Its just random sample variation. If you are not happy i would first test the lens and camera with another set of lens and camera to at least see which of the two is further away from the norm and just send that back to canon.
Jam.radonc
Jan 12, 2011 10:24 |  #15
All my lenses require +4 MA on the 5DII and none on the 450D. I wouldn't lose sleep over it.
Jam
5D3 | 450D | Panasonic DMC-LX3 | 430 EX II | ST-E2
24-70 L II | 50L | 50 1.8 I | 100L | Zeiss 35/2 ZE | Zeiss 85/2.8 | Zeiss 135/3.5
[COLOR="Silver"]Sold: 17-40L | 24L II | 85L II | 135L | Sigma 50/1.4 | 5D2
3,158 views & 0 likes for this thread, 10 members have posted to it.
1027 guests, 106 members online
