Thread started 11 Jan 2011 (Tuesday) 00:18
Which CPL to buy
Tribe
Jan 11, 2011 00:18 |  #1
Hey guys!
I did a quick search and didn't really find anything specific to this so this is my question: I really enjoy doing all sorts of photography but most specific landscape and portraits. My question is, based on my lenses (in sig), which size of CPL should I get first? I wanted a decent Hoya one and I can't afford to get a 77mm and 58mm at the same time (am a poor college student lol), so would which size would be more beneficial to get first?
Thanks for the help! (:
Claudia
6D | 450D | Canon 85 f/1.8 | Canon 50 f/1.4 | Canon 24-105L | Canon 10-22
HyperYagami
Jan 11, 2011 00:26 |  #2
77mm and a 58mm-77mm Step-Up Ring.
http://www.bhphotovide​o.com …mm_Step_Up_Ring​_Lens.html (external link)
5D3 and a few lens
es.
Tribe
Jan 11, 2011 11:22 |  #3
Ah! Didn't even know those existed! Thanks a lot. :D
Do you know if this CPL is any good?
http://maxsaver.net …lar-Polarizer-Filter.aspx (external link)
I saw there is better Hoya ones but my budget is $50 D:
Claudia
LittleFish
Jan 11, 2011 11:43 |  #4
http://www.lenstip.com …_Results_and_su​mmary.html (external link)
this is a website which shows the results of a test conducted on several polarizing filters. i think the one that you suggested ranks in at number 14. anyhow, check that website out. :)
|Canon T1i | 50 1.8 | 18-55 IS | 17-55 IS USM | Manfrotto 190XPROB and 498RC2 |
-Syed-
Wilt
Jan 12, 2011 17:10 |  #5
Cheap = more flare and contrast loss
Better to NOT buy a cheap filter at all, than to use a cheap filter...they have been PROVEN to HURT IQ!
http://www.kenandchris​tine.com/gallery/10543​87_ucZqa/1 (external link)
In my youth, I had a Tiffen PL, and discovered it to be a PRISM which caused distortion to whatever passed thru it...I crushed in under my heel, rather than pass on that horrid filter to some unsuspecting innocent via the used market!
shoturtle
Jan 12, 2011 17:23 |  #6
ebay for the 77mm to 58mm step up ring. Get a good cpl if you can. Hoya hmc is very. Here is a good read about cpl. They did not test the newer tiffen HT. But they are top notch as well.
http://www.lenstip.com …arizing_filters​_test.html (external link)
Traveling is my passion, so I am a major Frequent Flyer.
Canon 60D, T1i/500D, Eos 1, Eos 630, and Olympus epl-1. Current Canon Lenses ef 100 2.8, ef 85 1.8, ef 50 1.4, ef 28 1.8, ef 50 1.8,ef 28-135, ef 70-300, ef-s 18-55, ef-s 55-250, 500D close up lens. Current Olympus lenses oly m4/3 14-42, oly 4/3 35mm 3.5 macro with m4/3 adapter, panasonic 45-200, panasonic 20 1.7. And a Part time Pentax K-X shooter.
Tribe
Jan 12, 2011 18:23 |  #7
Thanks! I decided to just save for the remainder of the semester and hopefully order a B+W 77mm Kaesemann from Maxsaver.net and use the step up ring.
After a lot of research, I don't want to spend $50 knowing I'll want the Kaesemann later on anyways. Does anyone know about how long it takes to receive them (since they say special order I assume it's pretty long)? I'm planning a trip to Spain in late May and if I can afford it, I want to get it for the trip. Also, are they difficult to use? Should I order it and get familiar with it before the trip?
Claudia
shoturtle
Jan 12, 2011 18:32 |  #8
The kaesemann is really good, I use them for my smaller camera. Sorry I have you spending more with that article. The Hoya super HMC are really good as well. And are less expensive.
But I have gone exclusively with Tiffen HT's and BW MRC and the BW Kaesemann now for my cpl. And have been happy with the performance.
r.morales
Jan 12, 2011 19:21 |  #9
Tribe - good choice . I have kaesemann's for all my lenses .
No they are not hard to use . From about sunrise till around 10 AM and from about 2PM till sunset - you can use .
Have the sun so you see out of the corner of your eye or over your shoulder . If you can see your shadow , turn till you can't .
There is a white mark on the CPL , when closest or furtherest from sun - you get the most effect .
You can also get up to about 3 stops of ND with it .
Get a rubber hood for it and pop in one section , easier to adjust the CPL .
Wilt
Jan 12, 2011 19:28 |  #10
Using a Kaesemann is no different than using a non-Kaesemann, photographically speaking. From a handling point of view, Kaesemann edges are sealed to prevent mold in between the layers, so they do not need to be babied as much as non-Kaesemann PL filter.
shoturtle
Jan 12, 2011 19:35 |  #11
You can actually use it for other time and reasons only. They can be used to increase glare or decrease glare like at a auto show. Or when you are trying to get a reflection on or off a window. And they can also be used as a ND filter as they have about 3 stops.
sinjans
Jan 12, 2011 19:38 |  #12
shoturtle wrote in post #11627521 (external link)
+1 on the Kaesemann. I have one and it's smooth
Tribe
Jan 12, 2011 19:40 |  #13
Well, I've actually never used a CPL before, Wilt. Sorry haha. Thanks for the great advice r.morales and shoturtle.
Are you able to see the effect of the CPL in the viewfinder? Also, for cleaning can I use my Lenspen on it?
Claudia
shoturtle
Jan 12, 2011 19:42 |  #14
you can use a lens pen, no you will not see it in the view finder, buy you will see it in Liveview.
sinjans
Jan 12, 2011 20:09 |  #15
yes you will see it in the VF. Not as dramatic but noticable
4,957 views & 0 likes for this thread, 12 members have posted to it.
Which CPL to buy
1392 guests, 136 members online
