How can I or would it be possible to shoot HDR in Manual mode without touching the camera? I always use remote(tethered) switch. Camera 5D and 40D. Thanks.
eaglesnest Member 189 posts Joined Jan 2006 Location: Ontario, Canada More info | Jan 11, 2011 15:54 | #1 How can I or would it be possible to shoot HDR in Manual mode without touching the camera? I always use remote(tethered) switch. Camera 5D and 40D. Thanks. www.eaglesnestphotography.com
Bolter303 Junior Member 24 posts Joined Sep 2010 Location: Las Vegas Nv More info | Jan 11, 2011 17:14 | #2 Can you attach your camera to a laptop? If so Canon has a remote shoot program that lets you set you shots on the laptop and fire the camera from the lap top. Don Young
bailey239 Member 143 posts Joined Dec 2010 Location: South Florida More info | Jan 11, 2011 18:07 | #3 I must be missing something? I have a T1i and in manual mode I can still bracket exposures and trigger the camera by remote. Are you using more then 3 exposures? ~Josh~
Jan 11, 2011 23:13 | #4 Bolter303 wrote in post #11620172 Can you attach your camera to a laptop? If so Canon has a remote shoot program that lets you set you shots on the laptop and fire the camera from the lap top. Yes I know that, but it's quite difficult to carry your laptop if you're in the field/outside www.eaglesnestphotography.com
Jan 11, 2011 23:14 | #5 bailey239 wrote in post #11620497 I must be missing something? I have a T1i and in manual mode I can still bracket exposures and trigger the camera by remote. Are you using more then 3 exposures? Are you shooting in M (manual) mode? www.eaglesnestphotography.com
bailey239 Member 143 posts Joined Dec 2010 Location: South Florida More info | Jan 11, 2011 23:34 | #6 eaglesnest wrote in post #11622219 Are you shooting in M (manual) mode? Yes, I can do it in manual mode, It's not my normal shooting mode most the time so before i posted I tested to insure it works. ~Josh~
GaryMcDuffie Goldmember 3,022 posts Likes: 1 Joined Oct 2008 Location: Scottsbluff, NE USA More info | Jan 12, 2011 08:32 | #7 I'm not sure what the confusion is here. Run it in manual and set up your bracketing plus and minus whatever you want the spacing to be. Also set any exposure comp adjustment to bias one way or the other, or better yet, just offset the manual setting so the top or bottom of your bracket is whichever way you want it. Gary
Jan 12, 2011 09:58 | #8 Gary McDuffie wrote in post #11623779 I'm not sure what the confusion is here. Run it in manual and set up your bracketing plus and minus whatever you want the spacing to be. Also set any exposure comp adjustment to bias one way or the other, or better yet, just offset the manual setting so the top or bottom of your bracket is whichever way you want it. Thanks Gary, sometimes the way we think is too complicated. www.eaglesnestphotography.com
kirkt Cream of the Crop More info | Jan 12, 2011 10:20 | #9 Manual mode simply permits one to adjust, manually, ISO, aperture and shutter speed. There is no need for exposure compensation - just set the exposure. If you choose to use AEB, then pick your exposure bracket spacing (1 EV, for example). Use the timer and set the drive mode to multiple shots (burst mode). On most canon cameras, this combination will permit you to press the shutter release halfway to focus - do this and then set the lens to manual to keep the focus at this point. - then press the shutter release all the way and the timer will countdown and the camera will fire THREE shots without any more intervention. Kirk
ShaneW Senior Member 839 posts Likes: 2 Joined Jan 2008 Location: Traverse City, Michigan More info | Jan 12, 2011 10:25 | #10 Are you asking if you can bracket photos in M mode AND use a cable release to fire them off? The answer is YES. Shane W
GaryMcDuffie Goldmember 3,022 posts Likes: 1 Joined Oct 2008 Location: Scottsbluff, NE USA More info | Jan 12, 2011 11:16 | #11 Nice and complete, Kirt. Thanks for stating it even better. Gary
bailey239 Member 143 posts Joined Dec 2010 Location: South Florida More info | Jan 12, 2011 11:40 | #12 WOW kirkt, ~Josh~
| Latest registered member is ANebinger 1071 guests, 186 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
