Thread started 11 Jan 2011 (Tuesday) 17:17
Does formatting CF cards frequently decrease lifespan?
CitizenMinistry
Jan 11, 2011 17:17 |  #1
I was wondering if formatting should be done as little as possible and allow the card to simply fill up before formatting. Or is failure rate independent of formatting frequency?
Any other insight?
LostInInaka
Jan 11, 2011 17:26 |  #2
Good question, although i would say that if you are doing formatting in camera, it is a quick format of sorts that involves a simple rewrite of the mbr (or whatever) which is contained on a very small part of the disk (think about how when you format an 8GB disk, you don't get the full 8Gb....its because mbr/etc information is also stored on a small part of the drive)
Therefore only a small part is being changed and thus shouldn't have a huge impact on the drive
Now if you are doing a low-level format, that requires lots of writes and thus will impact the lifespan of your drive
I have my camera format my card after ever shoot, also helps keep any fragmentation (rarely a worry on flash memory anyway) down
5DmkIII | Rokinon 35mm f/1.4 | Canon 16-35mm f/2.8L mk II | Canon 24mm f/1.4L mk II | Canon TS-E 24mm f/3.5L mk II | Canon EF 24-70mm f/2.8L | Canon 70-200 f/2.8L IS mk II | + Misc
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Jan 11, 2011 17:58 |  #3
I am pretty sure that you will outgrow a card long before you wear it out.
Doc Klepper in the USA
I
ben_r_
-POTN's Three legged Support-
Jan 11, 2011 18:00 |  #4
rklepper wrote in post #11620449 (external link)
Thats what I was thinking.
And, FWIW I only format my cards in my camera, and I do it after every download to my computer.
x_tan
Gallery: 137 photos
Jan 11, 2011 18:18 as a reply to  @ ben_r_'s post |  #5
Just check your memory card "Minimum insertion/removal cycles".
Sample link: http://alltrands.com …8830-smartphone.htm/56671 (external link)
"Minimum 10000 insertion/removal cycles"...
Canon 5D3 + Zoom (EF 17-40L, 24-105L & 28-300L, 100-400L II) & Prime (24L II, 85L II, 100L, 135L & 200 f/2.8L II; Zeiss 1,4/35)
Sony α7r + Zeiss 1,8/55 FE
Nikon Coolpix A; Nikon F3 & F100 + Zeiss 1,4/50
Retiring  (external link)
yogestee
Jan 11, 2011 20:08 as a reply to  @ x_tan's post |  #6
Back to the original question,, no..
Jurgen
r.morales
Jan 11, 2011 20:25 |  #7
Yes , but you will never reach that point . Think of a demo camera in a store - how many shots has it taken ? Ever see a salesman say this is how easy it is to erase and just reformats the card ?
There is a better chance of corrupting a card by just deleting and not formating it .
Pictures just get to big for cards .
I have 4 mb cards that will never be used again because of size .
I delete the pictures after backing up to 2 drives and always format the card in camera
kingdaddy
Jan 11, 2011 20:25 |  #8
CitizenMinistry wrote in post #11620190 (external link)
Any other insight?
No, format a million times, no damage what so ever, a complete myth that it does.
6D | 7D | XSI | EF-S 10-22 | EF 50 1.4 | EF 24-105L | 100-400L │ EF-100mm Macro| MT-24EX │580 EXII | Black Rapid RS-5 | lots of Think Tank.
Wilt
Jan 11, 2011 20:55 |  #9
Even with removal and re-inserting the CF card 10000 times, you would have to do that every 10 photographs in order to match the shutter life MTBF (100000 actuations) ! CF memory supposedly handles 100000 write cycles (same bit written to 100000 times), IIRC.
r.morales
Jan 12, 2011 09:28 |  #10
There is a better chance of you getting dirt in pin scokets or bending pins .
FeXL
Jan 12, 2011 12:20 as a reply to  @ r.morales's post |  #11
We have 4 1GB SanDisk Extreme III's that we've used for 6 years. Nearly half a million images shot & downloaded between the 4 cards. Each time a card was downloaded, it was formatted in camera. A conservative estimate would be 500 formats each (more likely 600+).
We had one failure early on (two years old?) where we couldn't get a consistent read from the card, it was replaced under warranty, no issues since.
The cards still see light use & always get formatted in camera.
Recommended.
sebr
Jan 12, 2011 12:21 |  #12
Thats probably true... Unless you get one of those 128 GB card ;)
Sebastien
5D mkIII ; 17-40L ; 24-105L ; 70-200L II ; 70-300L ; 35L ; Σ85/1.4 ; 135L ; 100macro ; Kenko 1.4x ; 2x mkIII ; 580EXII
M5 ; M1 ; 11-22 ; 18-150 ; 22/2.0 ; EF adapter; Manfrotto LED
Benron Tripod; ThinkTank, Lowepro and Crumpler bags; Fjällräven backpack
CitizenMinistry
Jan 12, 2011 14:27 as a reply to  @ sebr's post |  #13
thanks for the replies!
hieu1004
Jan 12, 2011 15:06 |  #14
NO... format all you want.
-Hieu
Gear | Blog (external link) | flickr (external link)
solara
Jan 12, 2011 22:12 |  #15
Wilt wrote in post #11621453 (external link)
MTBF is NOT a measure of it's actual lifespan. It is the statistical "Mean Time Between Failures". Again, just statistics, not a true measure of actual lifespan.
And I'm sure most NAND these days don't even come close to write cycles of 100k!
5D III, 7D | 17-55 f/2.8 | 16-35 f/4 | 24-105 f/4 | 85 f/1.8 | 135 f/2 | 70-200 f/4 IS | 580EX II | YN-560 | Manfrotto 190XPROB+498RC2
3,820 views & 0 likes for this thread, 16 members have posted to it.
1343 guests, 130 members online
