Thread started 13 Jan 2011 (Thursday) 18:34
New 50mm 1.8 day for me!
Max ­ Powers
Jan 13, 2011 18:34 |  #1
Hey guys, just got this lens today. It is now my second lens and I am enjoying it!
One question though. I took a test shot on my pool table and I noticed something weird. To me at least!
There's a strip that is in focus on the carpet of the pool table. Is that normal? It's like everything before and after the 4 ball is out of focus, then where the 4 ball is, which is what was focused on, there is a strip that is in focus. Should it not just focus on the ball and throw everything else out of focus? Is this because the lens is cheap?
IMAGE: http://i5.photobucket.com/albums/y167/Max_Powers/IMG_1004.jpg
***Edit! one more question!
All the lights look like stars and it's quite ugly. Everything else is so sharp and amazing imo. Has anyone else experienced this? Is this lens just out of the question for this type of stuff?
I took these pics at f/22 with a 30 sec exposure.
IMAGE: http://i5.photobucket.com/albums/y167/Max_Powers/IMG_1034.jpg
IMAGE: http://i5.photobucket.com/albums/y167/Max_Powers/IMG_1037.jpg
Nikon D600
-Samyang 14mm f2.8 -Nikon 50mm 1.8G -Nikon 70-200mm f2.8 VR
-Nikon 24-120 f3.5-5.6 D
flickr (external link)||500px (external link)
DAMphyne
"the more I post, the less accurate..."
Joined Feb 2003
Jan 13, 2011 18:42 |  #2
No, it's working the way it should.
The lens doesn't focus on a "spot", it focus across the field of view.From one side to the other.
Someone will surely explain this effect better than I.
David
Digital set me free
"Welcome Seeker! Now, don't feel alone here in the New Age, because there's a seeker born every minute.";)
www.damphyne.com (external link)
Terry ­ Clair
Joined Nov 2010
Jan 13, 2011 18:43 |  #3
Everything in the same plane as the 4 ball will be in focus.
gva1.zenfolio.com
Canon 40D, Canon G9 and way to many others...
ChewieT
Joined Nov 2010
Jan 13, 2011 18:45 |  #4
Anything that is in the same focal plane as the ball will be in focus. Working on 3 planes lets call this the Z plane. There are 2 other planes X and Y (horizontal and vertical). If an object is in the same Z plane as the focus object (the ball) it will be in focus. Its position in the X and Y plane have no affect on whether it will be in focus.
Gripped Canon 7D | Gripped Canon 50D | EF 70-200mm f/2.8L IS MkII | EF 24-70mm f/2.8L | EF 135mm f/2.0L | EF 24mm f/1.4L II | EF-S 10-22mm f/3.5-4.5 USM | EF-S 18-55mm f/3.5-5.6 IS | EF-S 55-250mm f/4-5.6 IS Lens | 2 x 580EX Mk II | Manfrotto 055CXPRO3 | Manfrotto ball head Midi 498RC2 | Lowepro Flipside 400AW
http://www.tuckshots.c​o.uk (external link)
Max ­ Powers
Jan 13, 2011 18:58 |  #5
huh, cool, thanks for the info. now what would be the correct way to shoot this? or is this acceptable?
Nikon D600
deloreangirl
Jan 13, 2011 20:02 |  #6
Max Powers wrote in post #11635494 (external link)
I just got mine last week as well. I know what you mean about that depth looking odd (with that part of the table in focus). Perhaps if you shot up at the ball, not capturing the table it may work. I think it mainly does this on horizontal surfaces. You don't really notice it in a shot where a person is standing at a specific distance away from you.
;) Emily
Rebel T2i | EFS 18-55mm | EF 50mm 1.8 II | EF-S 55-250mm | EF 35mm 2.0
absplastic
Gallery: 40 photos
Jan 13, 2011 20:09 |  #7
That's perfectly normal, and nothing to do with the cost of the lens. This is how one would expect it to look taken with a standard lens at a wide aperture. When you focus on something, and you're using a wide aperture like this, you get a focal plane at a fixed distance from the lens, and only things very close to that plane are in critical focus. The more you stop down, the greater the depth-of-field becomes (the range in front of and behind the focal plane where things appear in focus).
With standard prime lenses the focal plane is effectively flat and parallel to the sensor. Tilt-Shift lenses give you more control over where the focal plane is, allowing you to tilt it away from being parallel with the plane of the sensor.
5DSR, 6D, 16-35/4L IS, 85L II, 100L macro, Sigma 150-600C
SL1, 10-18 STM, 18-55 STM, 40 STM, 50 STM
My (mostly) Fashion and Portraiture Instagram (external link)
flickr (external link) (NSFW)
PhotoImposter2
Jan 13, 2011 20:10 |  #8
DAMphyne wrote in post #11635408 (external link)
Thanks! I got the same lens and my photos came out blurry.
Nic ­ L
Jan 13, 2011 20:31 |  #9
nice shot
7D|Sigma 17-50mm 2.8 EX OS|70-200mm F2.8L|24-70mm F2.8L|580 EX II| NIC L
Max ­ Powers
Jan 14, 2011 01:26 |  #10
2nd question added
Nikon D600
themadman
Jan 14, 2011 01:29 |  #11
1. The area of focus is a plane parallel with the sensor, so the strip of table should be in focus as would anything directly above it.
2. Star Lights are normal, I think aperture blades may change how they look slightly, but I am pretty sure most lenses gives some form of star shape.
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
kaptnkain
Gallery: 33 photos
Joined Nov 2010
Jan 14, 2011 01:29 |  #12
A lens can focus on a plane that is perpendicular to itself. The larger the aperture, the thinner that plane becomes. So yes, when you focus on the ball, anything around it that is in the focus plane will be in focus.
As for the stars, this happens when shooting at large apertures with long exposures.
- Ilya
Max ­ Powers
Jan 14, 2011 03:07 |  #13
However, I have shot many long exposures with my 17-85 lens and haven't gotten that same effect. It's a pretty drastic difference when compared side by side.
EF-S 17-85
IMAGE: http://i5.photobucket.com/albums/y167/Max_Powers/IMG_0616-1.jpg
EF 50 1.8
Nikon D600
ohericcc
Jan 14, 2011 06:45 |  #14
For the pool ball, that is because your depth of field is shallow. This blurs out everything in the rear and this happens when your aperture is big (smaller f-stop number)
The 50mm f/1.8 is composed of a 5-blade diaphragm so the starlight appears that way in long exposures.
Canon 7D | Canon T1i | 11-16 2.8 | 35-80 (macro modded) | 18-55 IS |17-55 IS | 50 1.2L | 135 2.0L | 70-200 2.8L
Max ­ Powers
Jan 14, 2011 07:14 |  #15
ohericcc wrote in post #11638206 (external link)
For the ball, I know what the depth of field is. I was just wondering why there was a line of clearness with out of focus before it. It has been explained since though.
As for the lights, I realize that now. Well, this lens will have to stick to daytime and short exposure duty.
I can't stand the look of those star lights lol.
Nikon D600
4,030 views & 0 likes for this thread, 16 members have posted to it.
1439 guests, 134 members online
