Thread started 13 Jan 2011 (Thursday) 22:00
Polarize Filter...?
Soto
Jan 13, 2011 22:00 |  #1
Hello,
I'm doing research on polarizer filters and I would like to read from the people here about which one is good and not to expensive... (up to $125 or $150).
Which one you guys recommend?
It would be to use it with my Canon 24-105mm... Also, which other filter would you recommend for landscape photography?
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
Jan 13, 2011 23:36 |  #2
125 to 150? You are very close to quality vs pricing. If you have to go a bit over the $150 limit do so. I also have the 24-105 and use a B+W polarizer.
Image Editing OK
Superdaantje
Jan 13, 2011 23:41 |  #3
I use for the 24-105 the B+W MRC Slim. Works perfect ;-)a
Wagner.photography -  (external link) Workshops photography in the Netherlands & Indonesia -_-
Gear list (external link)
20droger
Jan 14, 2011 08:35 as a reply to  @ Superdaantje's post |  #4
Look at it this way. The EF 24-105mm F/4L IS USM is a $1059 lens (B&H). Do you really want to stick a cheap filter on the front of it and throw away everything that makes it an "L"?
All it takes is one piece of crap glass anywhere in the light path to produce crap pix.
IslandCrow
Jan 14, 2011 08:49 |  #5
One of the B&W Multi-coated filters should work out well for you. That's what I use on all of my lenses. Does the 24-105 use a 77mm thread size? If so, I'm thinking you could pick one up for around $150 or less if you shop around. I've always been a B&W fan, but also check out Hoya's multi-coated filters. They're also very good quality.
Dr ­ Lazarus
Jan 14, 2011 08:56 |  #6
As for your second question, a couple of graduated neutral density filters will help out quite a bit.
V-Wiz
Joined Sep 2009
Jan 14, 2011 11:07 |  #7
You want the BW KSM CPL. Get it trust me.
Gripped 5D Mark II l 24-105 F/4 L l 70-200 F/4 L l Tokina 12-24 F4 l 50mm 1.8 l Sigma 600 Mirror l B+W KSM CPL l B+W 6stop ND filter l Hitech 0.6 GND l YN-468 Flash l Kenko Pro 300 1.4 TC l Induro Tripod, Vanguard 250 Ballhead.
Soto
Jan 14, 2011 11:38 |  #8
20droger wrote in post #11638652 (external link)
That's why I want to use a very good filter... which one would you recommend?
Soto
Jan 14, 2011 11:41 |  #9
V-Wiz wrote in post #11639666 (external link)
Can you give me a direct link from B&H?... or part #
Chippy569
Jan 14, 2011 14:41 |  #10
http://www.bhphotovide​o.com …_Circular_Polar​izing.html (external link) -- assumed you want 77 but i don't know.
KSM is for Kasemann-style filtration
David Nichols (external link) - Sound Designer
How to export to Youtube HD from Quicktime
Soto
Jan 14, 2011 17:55 |  #11
Thanks.... the Canon 24-105mm is 77
birdfromboat
Location: somewhere in Oregon trying to keep this laptop dry
Jan 14, 2011 22:28 |  #12
cokin has been fine for me. 77mm holder fits most of the L zooms, goes on and off quickly and adjusts easily, and if you leave the filter in the cokin holder and take the holder on and off, the filter is somewhat protected as opposed to being just a flat filter needing a box. I should know, I dropped mine last week and it actually bounced off the cement unharmed.
5D, 10D, G10, the required 100 macro, 24-70, 70-200 f/2.8, 300 f2.8)
Looking through a glass un-yun
windpig
Chopped liver
Jan 14, 2011 22:34 |  #13
Chippy569 wrote in post #11641278 (external link)
Get this. Great lens needs a great filter, plus 77 is a common filter size. You can get step down rings for smaller lens diameters.
Go ahead, spin the wheel.
V-Wiz
Joined Sep 2009
Jan 17, 2011 10:42 |  #14
Soto wrote in post #11639887 (external link)
Get it from maxsaver.net. Much cheaper than anywhere else. Thats where everyone gets it from
2,527 views & 0 likes for this thread, 10 members have posted to it.
Polarize Filter...?
928 guests, 150 members online
