Thread started 13 Sep 2005 (Tuesday) 18:56
Is the 580EX worth the extra 80 bucks?
NBEast
Gallery: 11 photos
Sep 13, 2005 18:56 |  #1
I'm a flash novice. Have a 20D. Want to shoot at a wedding reception.
Will the 580 help cover my inadequate flash experience, over the 550? Are any major 550 issues addressed with the 580 release? Can I go cheap and get the 430?
Any other good flashes one might advise?
Wedding is in 10 days so need to order now.
Gear List / Photos (external link)
jrsforums
Sep 13, 2005 19:16 |  #2
If you just want to start out and save $s, suggest you get 420EX at B&H @$175. plus shipping.
http://www.bhphotovide​o.com …EY&addedTroughT​ype=search (external link)
You can get a 580EX later to use as master or more power if you really get into flash work.
If $s are no object, the 580EX is worth it...more power than 420/430, manual settings, and can be master...also, smaller, lighter, and faster recharge than 550. I have one (just got a 2nd) and love it.
John
John
NBEast
Gallery: 11 photos
Sep 14, 2005 01:07 as a reply to  @ jrsforums's post |  #3
John
Thanks.
Why 2 580's? Don't know what a "Master" is, but fast and small sound desirable. You recommend Canon all the way?
Saving $200 is tempting (a $179 400 series) since I will rarely use it, or going off brand (Sigma?), but someone said not to chince on the flash.
PJGrove
Sep 14, 2005 01:54 as a reply to  @ NBEast's post |  #4
I've just ordered the 580EX and I've bought it specifically for a wedding I will do Sunday 25th. As soon as I get it I need to practise because, like you, I haven't used one before. I toyed with the idea of getting a different model but from extensive reading in these forums decided on the 580EX. Good luck with your decision and I'd love to see some results.
Paul
:D
Canon EOS 350D (black)
Canon BG-E3 Battery Grip
Canon EF-S 18-55mm f/3.5-5.6 Lens
Canon EF 55-200mm f/4.5-5.6 II USM lens
Canon Speedlite 580EX
:shock:
bachscuttler
Joined Oct 2004
Sep 14, 2005 02:11 as a reply to  @ PJGrove's post |  #5
I'll be buying the 580 very soon.
I know next to nothing about flash, but this was an excellent read...
http://photonotes.org/​articles/eos-flash/ (external link)
camerastageleft.com (external link) |1D MkIII x2 | 350D | 17-40L | 24-70L | Nifty Fifty | 70-200L f4 | 100-400L IS f4/5.6 | Yongnuo PT-04 radio trigger/receivers | Slik Pro 700DX Tripod | Speedlite 580EX Mk1 + MkII & 430EX MkII | Cotton Carrier Vest + ever growing mountain of strobist gear.
Salleke
Sep 14, 2005 03:35 |  #6
Yes it's worth the extra money.
René ­ Damkot
Sep 14, 2005 04:37 |  #7
Worth it, on ergonomics alone: Head turns 180 degrees left _and right_ (at last), one release for tilt/turn, wheel instead of buttons, one button (instead of 2 at once) to press to get 2nd curtain sync/HSS. I still have the 550, but as soon as budget allows :p
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
etaf
Sep 14, 2005 04:47 |  #8
for weddings I would buy the 580 - I purchased the 550EX and its a great flash - the chances are if you purchased something cheaper you will only end up buying it later
also the guide number of 580 is 58 whereas the 430 is only 43
Get some NiMH Batts and you will find great recharge time, the 550 is a great fill flash at weddings
also the 580 is colour balanced and zoom control for the 20D
good luck
60D | EF-S 18-200 | 50mm 2.5 macro | 550EX | Pro1 | Elements
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Sep 14, 2005 07:06 |  #9
I like the 580's faster recycle times :)
CDS' HOT LINKS
jrsforums
Sep 14, 2005 08:03 as a reply to  @ NBEast's post |  #10
NBEast wrote:
Thanks.
I wanted the 2nd 580 for the stated reasons in my post, plus backup for #1, plus, if I ever want to, the 580 can be set manually where the 4xx series cannot.
I have not, recently, tried other flashes, so you will need to ask someone else on the tradeoffs vs. other non-Canon flashes. The Canon 580 has not, in any way, disappointed me....in fact, confirmed by my second purchase.
John
John
Jwreich
Sep 14, 2005 15:41 |  #11
I like my new 580. Got on a deal from Dell and it actually arrived within 3 weeks. I was impressed. Nevertheless, I sold a Sigma 500 because it always seemed to be a stop over exposed, the Canon 550 and 580 seems just perfect. I would like to add a new 430 EX but at $299 I can't see the value over the 420 or even some used 550's.
If you can go Canon. They make great flashes and the 580 is awesome in my book. Very glad I make the investment. That's what it is, an investment.
Regards,
--JWR
EOS5D + Grip, 1D MkIII
Tamron 28-75 2.8, EF 70-200 L f2.8 IS EF 16-35 L
EF 24-105 L f4 IS, 50mm 1.4, 35 L, 85 1.8, 580EX x4, SB28 x6
www.jessereich.com (external link)
Lotto
Sep 14, 2005 20:51 as a reply to  @ Jwreich's post |  #12
I went the same route like others here, 420 first, now bought the 580. Then I found out I like the multi flash setup a lot, but now I kind of regred getting the 420 first, because it dosen't have manual controls.
So on that I would say get the 580 first, wedding photographer deserve the best:D . Then add a 550 or 430 later for back up or use as multi speedlite setup.
5D, 24-105L, 70-200L IS, 85mm Art, Godox
NBEast
Gallery: 11 photos
Sep 14, 2005 21:15 |  #13
Thanks everyone. I'm sold. The 580's worth it. Ordering tonight.
pcDigiMan
Sep 14, 2005 21:34 |  #14
Love It - 580EX
Cheers,
Bob - A Swell Guy
7D, 20D, EF-S 17-85mm f4/5.6 IS, EF 24-70mm f/2.8 L, EF 70-200mm f/2.8 L IS, 2x II, 580EX, 430EX (x3).
Ronald ­ S. ­ Jr.
Prodigal "Brick" Layer
Gallery: 12 photos
Sep 14, 2005 21:45 |  #15
As far as recycle times..I can shoot my xt's 3 fps, and probably 7 or 8 out of 10 shots, the 580 fires. Now that's what I call quality.
I've seen side by side results from a 430,550, and 580. 580 takes it. I use it constantly. Well worth the minor extra. As someone said before, "don't chince on your flash". A flash can make or break a good shot.
Mac users swear by their computers. PC users swear at theirs.
4,044 views & 0 likes for this thread, 12 members have posted to it.
1503 guests, 135 members online
